VSS and what does it do?
OK, I've installed my constant speed VSS circuit and it enables full RPM.
BUT the darn thing runs like crap. BOGs from 2500 to 4500 and then leaps to 8000. This might be OK on the drag strip, but in autocross, that is not good.
I think I may need to make VSS work like it's supposed to.
2002 RSX S engine, standard ecm and harness, Toyota transmission, Lotus 7 clone chassis.
Del Long
Del Long
VSS=Vehicle Speed Sensor
Normally it tells the speedo how fast you're going...and the most important part for the enthusiasts is that it tells the ECU that you're going faster than 13MPH which is one of the 3 triggers for vtec...the other 2 are oil pressure, and coolant temperature.
Austin
P.S. - would be interested in some pics...the rotus 7's are kinda fun
Austin
I build these for fun and they're always for sale. This one will be in the $25 range.
Last years won the 2001 SCCA D Mod Championship. I'd like to see the same think happen again, but I have to get it running better than it is so far.
Del Long
Del Long
