Low frequency to High frequency VSS help
Old Jan 3, 2009 | 05:06 PM
Mr.Burner's Avatar
Icon2 Low frequency to High frequency VSS help
Basic problem, i have a countershaft speed sensor style trans (05-08 rsx-s) with 02-04 harness with newer k-pro....(k-pro has the fix)
Car is 2000SI
i've seen alot of posts on other web sites about using a box to slow the speed of the counter....not into that.
I have the countershaft pig tail and its wired up as if it were a 05+ rsx to the ecu.
In the k-pro i can go to Misc and switch it to 05+ rsx countershaft...done that and its not working.....
Anybody else know what im doing wrong or has done this? Not switching cases or wiring in a box, nor buying another trans.
thanks...
Old Jan 4, 2009 | 05:22 PM
Mr.Burner's Avatar
Default Re: Low frequency to High frequency VSS help
bump for no vtec
Old Jan 4, 2009 | 05:32 PM
locash's Avatar
Is the k-pro seeing vehicle speed while you drive? Is it just the car's speedometer that isnt working?
Even better, have your tuner fix it when you pay him to tune the car.
Old Jan 5, 2009 | 10:30 AM
Mr.Burner's Avatar
doesnt read ****....
i'll be over there when i get off work...
10psiLsEf2
Dec 12, 2011 07:02 PM
Mr.Burner
Jan 5, 2009 11:18 AM
ktwampdc5
Oct 20, 2008 08:01 AM
808DB1
Nov 22, 2007 09:55 PM
