Emission/Idle/MPG Problems
Old Sep 25, 2008 | 08:17 AM
JDMReverend's Avatar
Default Emission/Idle/MPG Problems
My car want's to idle at 2k+ plus rpm, even with the clutch in. It failed emissions, said lots of unburned fuel, and my gas mileage went to ****. Whats wrong?
Manual B16A in the del Sol.
Old Sep 25, 2008 | 08:47 AM
mikehawk's Avatar
Default Re: Emission/Idle/MPG Problems (JDMReverend)
Have you checked the IACV? Mine was idleing at 2-3k and I replaced that and it sits about about 1200 now... I picked up one at the junkyard for $6
Old Sep 25, 2008 | 09:30 AM
honda_joe's Avatar
Can you give us more info?
When did this problem start? CEL's? Any recent modifications or work done to the car?
Old Sep 25, 2008 | 10:51 AM
Default Re: Emission/Idle/MPG Problems (honda_joe)
Can't post CEL's cause it won't tell me what codes it's throwing. I'm thinking possible bad ecu. Start the car up, cel is lit, and if you jump the plug to get it to throw codes, it stays solid. Tried disconnecting the negative and removing the ecu and the backup fuses and it won't reset, or the light comes back on immediately and still idles high.
Old Sep 25, 2008 | 12:26 PM
Jonathan_ED3's Avatar
The CEL will stay solid if there are no codes stored when you are jumping the service connector.
Are you sure you are jumping the harness properly? A lot of people try to use paperclips--- a lot of paperclips have a coating on them and they won't conduct.
92bseries
Dec 7, 2011 12:59 PM
decko
Jan 25, 2011 06:27 AM
HOUSTONtx
41
Jul 17, 2008 12:09 PM
AzN_Flava
Jan 12, 2007 04:12 AM
