Need information about D16 B VTEC series..
Old Sep 24, 2008 | 11:19 PM
bombfox's Avatar
Default Need information about D15 B VTEC series..
hi i need some information for:
- a best manual tranny to D15B or
-a best tranny automatic
is for a turbo proyect but this engine have a tranny automatic and for moment no think to swap to a manual tranny.
btw: have a confusion and is true de D16B no exits! excuse me the last poster for de confusion.
Modified by bombfox at 10:17 AM 9/25/2008
Modified by bombfox at 10:41 PM 9/26/2008
Old Sep 25, 2008 | 05:15 AM
baller status's Avatar
Default Re: Need information about D16 B VTEC series.. (bombfox)
"Cable" and "Hydraulic" don't apply to automatic transmissions since they don't have a clutch. You need a 96-00 auto tranny if you have a 96-00 chassis. The gearing for all of them is the same I believe except for the CVT from the Civic HX; which you do not want unless you have a Civic HX.
Old Sep 25, 2008 | 05:25 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bombfox &raquo;</TD></TR><TR><TD CLASS="quote">HI
i need info for a D16 B VTEC engine....and best tranny to combined this...tell me about especification for this engine and the best tranny for. I have a 98 civic hb automatic tranny with this engine. please indicated the tranny for best combinated is hidraulic or cable or best automatic transmition ....thanks a lot </TD></TR></TABLE>
Your post is very confusing. If you are swapping in a 5 speed then a hydraulic transmission is the way to go. If keeping with the automatic then you will need one from a '96 - '00 civic. As baller status stated don't get an HX CVT or the CVT/Multimatic transmission that often comes mated to the D15B 3 stage vtec engine.
Old Sep 25, 2008 | 09:05 AM
bombfox's Avatar
Default Re: Need information about D16 B VTEC series.. (94EG8)
i have this engine in my civic sure exits the short block series identification is D16B
Old Sep 26, 2008 | 09:43 PM
bombfox's Avatar
Default Re: Need information about D16 B VTEC series.. (baller status)
you have a reason dont exits..clean de area when is de serial number of the engine an is a d15B excuse me men...
Old Sep 26, 2008 | 10:38 PM
boostedhks's Avatar
um.. u know u cant put an automatic engine on an auto car without a conversion right ?
Other than that, best single cam 5 speed tranny is one from an EX civic single cam. Best tranny u could find for d-series, a dx tranny is very good too but ex is top of the line man.
Old Sep 27, 2008 | 06:27 AM
dj_gizmo's Avatar
Default Re: (boostedhks)
the only problem i have with an ex tranny is the shortness of 1st to 3rd gear
i'm trying to find a tranny with more ballz
Old Sep 27, 2008 | 09:19 AM
sde780's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedhks &raquo;</TD></TR><TR><TD CLASS="quote">um.. u know u cant put an automatic engine on an auto car without a conversion right ?
Umm you know you sure CAN put an auto engine in an auto car without a conversion right? WTF are you talking about?
OP what are you trying to do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OP &raquo;</TD></TR><TR><TD CLASS="quote">is for a turbo proyect but this engine have a tranny automatic and for moment no think to swap to a manual tranny.</TD></TR></TABLE>
why would you use an auto tranny for a turbo project, it's gonna be a pain in the *** and you'll be limited compared to a 5-speed.
Old Sep 27, 2008 | 10:46 AM
turbojdmhatch's Avatar
Default Re: (dj_gizmo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj_gizmo &raquo;</TD></TR><TR><TD CLASS="quote">the only problem i have with an ex tranny is the shortness of 1st to 3rd gear
i'm trying to find a tranny with more ballz </TD></TR></TABLE> thats almost sig material
a tranny with more *****?
Old Sep 27, 2008 | 10:52 AM
94EG8's Avatar
Seagull Management
Ok, i'm still confused as hell. To the OP, what engine/transmission do you have now? and what exactly are you trying to do? I think you are confusing the word exits with the word exists. I think you are saying you are turboing a D15B and you want to know the best automatic transmission to use and you think that an automatic will be ok for now? I really need to know what car this is in (year, model and trim level) But usually it makes far more sense to use a manual tranny, automatics usually don't last long when you use a turbo.
Old Sep 27, 2008 | 11:49 PM
bombfox's Avatar
Default Re: (94EG8)
ok the car is a civic 98 hatch cx... engine D15B with automatic cx tranny. i understand the point....the 5 speed tranny is the major combinated....but in case no swap the tranny automatic to manual...my question is clear....which is the best or strong aut. tranny ....or which is the best tranny 5 speed manual? is clear my question...i have plan A and plan B you know? so is two question ...
Old Sep 28, 2008 | 06:40 AM
bigD's Avatar
Default Re: (bombfox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bombfox &raquo;</TD></TR><TR><TD CLASS="quote">ok the car is a civic 98 hatch cx... engine D15B with automatic cx tranny. i understand the point....the 5 speed tranny is the major combinated....but in case no swap the tranny automatic to manual...my question is clear....which is the best or strong aut. tranny ....or which is the best tranny 5 speed manual? is clear my question...i have plan A and plan B you know? so is two question ... </TD></TR></TABLE>
As someone else already said the ex tranny auto or 5 spd is your best option. Short gears are going to help you not hurt you.
Old Sep 28, 2008 | 07:21 AM
thumper64's Avatar
You plan to turbo the engine, but want an automatic? I haven't heard of any shift improver kits, or any way to adjust the shift points for our Civics, so unless one of those exists, you may as well put in a manual trans.
The best manual trans would be from 96-00 since it has steel shift forks.
Old Sep 28, 2008 | 03:45 PM
sde780's Avatar
^ and the EX model has the shortest gears i think, which is what EVERYONE's been telling the OP.
sooo
1. Auto-manual swap
2. use EX tranny
3. boost
4. post up numbers and pics on HT
Old Sep 28, 2008 | 04:21 PM
VtecSyndrome's Avatar
Default Re: (sde780)
bad spelled I do.. speak bad some english pardoning me please ...typing language bad so too combinated sense I make little no of...
OMG my head hurts now from trying to speak your language maybe I should go post some random *** attempt of writing in chinese for my lst time ever on some other forum just to see if they laugh as hard as everybody else that attempts to make sense of your hacked up question's here. Do you actually expect to really learn something here with your total lack of knowledge of the english language?
Honda-tech FTmfW!
Old Sep 29, 2008 | 11:49 PM
bombfox's Avatar
Default Re: (VtecSyndrome)
thanks 4u comments...but in spanish traduce this: ME IMPORTA UN CARAJO LO QUE PIENSES CABRON! I REGISTERED IN THIS PAGE BECAUSE CHANGE IDEA WITH OTHERS MEMBER ...
Old Sep 29, 2008 | 11:55 PM
bombfox's Avatar
hey i from Puerto Rico and in the street i see turbo cars with aut. tranny and run very faster. So only write tha question for suggestion....a friends tuner Civic say to me the automatic civic 95 ex is perfect for aut.
Old Sep 30, 2008 | 05:26 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bombfox &raquo;</TD></TR><TR><TD CLASS="quote">hey i from Puerto Rico and in the street i see turbo cars with aut. tranny and run very faster. So only write tha question for suggestion....a friends tuner Civic say to me the automatic civic 95 ex is perfect for aut. </TD></TR></TABLE>
If you are going to turbo put in a manual. you need to run an ODB1 ECU so you can tune. OBD1 ECU in an OBD2 car will not be able to control the automatic tranny. You'll need to use a transmission from a '92 - '95 civic and maybe do some rewiring in order to get it to shift right. '95 civic trannys suck IMO. the '92 - '94 automatic transmission seems to be better. Automatic transmission don't last long anyway with a turbo, its a much better idea to go with a manual.
Old Oct 2, 2008 | 07:55 PM
bombfox's Avatar
Default Re: (94EG8)
ok...i understand ....is better swap to manual tranny. what tranny to serie D is with LSD ?
Old Oct 2, 2008 | 08:00 PM
94EG8's Avatar
Seagull Management
JDM OBD1 D15B vtec has the only d-series tranny i know of with an LSD. Not all of them had it either, it was an option
Old Oct 6, 2008 | 09:13 PM
bombfox's Avatar
Default Re: (94EG8)
it was an option or have more choices....
Old Oct 7, 2008 | 04:06 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bombfox &raquo;</TD></TR><TR><TD CLASS="quote"> it was an option or have more choices....</TD></TR></TABLE>
It was an option. Some had it, some didn't.
impr323
Jul 18, 2007 10:58 PM
coupe99vtec
46
Feb 18, 2005 10:10 AM
hvn4life
Nov 30, 2004 05:56 PM
Civic4less
Sep 4, 2004 07:15 PM
99lsvtecauto
Oct 30, 2003 09:22 AM
