Crank Fluctuation Sensor (CKF Code 54) Did search
Old Sep 24, 2008 | 08:19 PM
Spec R's Avatar
Default Crank Fluctuation Sensor (CKF Code 54) Did search
Hey guys,
I've searched all over the net, on the CEL code 54, but all I get is something in the lines of:
-solutions to trick the computer
-replace the sensor
-swap related advice (jdm into usdm etc)
-obd2-obd1 jumper harness
None of the threads/topics I came up searching had actual solutions to why the Crank Fluctuation may have been detected in the first place.
Assuming everything is wired and functioning correctly, what would cause this CEL 54 to turn on?
The reason I ask, is that mine came on when I was backing out of my driveway (uphill) and I'm thinking the vibrations from the clutch chatter and grabbing may have set it to turn on.
I disconnected the battery and the light hasnt returned. I'm under the assumption that the sensor detected a fluctuation (in this case, probably a misfire during a near-stall situation, like me backing out of my driveway).
Thanks in advance.
Oh yeah its a 1997 Integra GS 5speed
Modified by Spec R at 9:31 PM 9/24/2008
Old Sep 28, 2008 | 09:27 PM
Spec R's Avatar
Default Re: Crank Fluctuation Sensor (CKF Code 54) Did search (Spec R)
the light returned today, any insight?
Old Oct 7, 2008 | 02:21 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
http://technet.ff-squad.com/ckftrick.htm
Old Oct 7, 2008 | 02:41 PM
Ryan#1's Avatar
Hiding a fault from yourself doesn't fix your car. Why would someone cheat themselves out of a proper and realiable running car with a simulated repair like that. It's just for pretend, I think he actually wants to fix his car.
No other faults? You should not erase the faults, that way it'll eventually stored a misfire fualt and tell you which cylinder to check out. How do your plugs look?
Old Oct 7, 2008 | 02:49 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (Ryan#1)
its a trick.
its a simple fix by putting a new one on or tricking the ecu. I don't see the problem. same way for people that have Honda civic CX, and want to get ride of the fuel sensor code because they don't have it, you trick the ecu to see 5 volts to that sensor. doesn't hurt a thing.
Old Oct 7, 2008 | 10:23 PM
Spec R's Avatar
Default Re: (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">its a trick.
its a simple fix by putting a new one on or tricking the ecu. I don't see the problem. same way for people that have Honda civic CX, and want to get ride of the fuel sensor code because they don't have it, you trick the ecu to see 5 volts to that sensor. doesn't hurt a thing.</TD></TR></TABLE>
thanks for the posts, but if you read closely, i'm not trying to "trick" my system.
Old Oct 7, 2008 | 10:27 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys,
-replace the sensor
hmm, i did read it wrong
then just put a new sensor in it and call it a day
Modified by HybridcivicLS-T at 1:33 AM 10/8/2008
pityocamptes
12
Dec 14, 2011 09:48 AM
underb00steg6
Apr 1, 2009 11:13 AM
scoobyghost
Jun 19, 2004 12:21 PM
