Whats the correct way to rotate the crankshaft pulley?
Old Sep 24, 2008 | 06:18 PM
supermotothud's Avatar
Default Whats the correct way to rotate the crankshaft pulley?
Im removing my transmission on my 96 Ex auto trans.
Its to replace a leaking Rear main seal.
Old Sep 24, 2008 | 06:19 PM
Ross 2.0's Avatar
In a Junkyard near you.
use a 19MM socket and a long handle ratchet. Honda also has a special tool you can rent from a parts store.
Old Sep 24, 2008 | 07:31 PM
02 accord's Avatar
Default Re: Whats the correct way to rotate the crankshaft pulley? (supermotothud)
Pull out the spark plugs; it will make your life much easier.
Old Sep 25, 2008 | 03:21 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supermotothud &raquo;</TD></TR><TR><TD CLASS="quote">Whats the correct way to rotate the crankshaft pulley?</TD></TR></TABLE>
in case you were asking which direction to turn it, that would be counter-clockwise.
If I am rotating the crank during a timing belt change I just slip the pulley back on and use the special tool to rotate it. If I'm just doing a valve lash adjustment or something where I'm not removing the pulley, then I just use a 19mm socket on the crank pulley bolt.
Old Sep 25, 2008 | 03:23 AM
H-T Order of Merit
Default Re: (Ross 2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross 2.0 &raquo;</TD></TR><TR><TD CLASS="quote">Honda also has a special tool you can rent from a parts store.</TD></TR></TABLE>
I have yet to personally see one for rent in any parts store around me.
What stores have you found that rent this tool?
Old Sep 25, 2008 | 04:19 AM
Ross 2.0's Avatar
The advance auto near my dealer has them. Both sizes. But I guess it's rare?
rarrior23
Dec 28, 2007 01:35 PM
SECURITY
11
May 24, 2007 09:43 PM
jdm_vtec
13
Dec 3, 2006 05:06 PM
sickerhatch
Sep 28, 2005 06:24 PM
duececoupe2
Feb 28, 2005 08:04 PM
