intake swap question
Old Sep 24, 2008 | 06:00 PM
ryanevansoh's Avatar
Default intake swap question
hey my buddy has a 96 hx coupe with a stock d15y5 in it. i was wondering if it is possible to swap the the intake manifold for one out of a d16a6? i just want to know if it would bolt in, and if there would even be a power increase? thanks
Old Sep 24, 2008 | 06:58 PM
Apotheosis's Avatar
Default Re: intake swap question (ryanevansoh)
if the following is incorrect, someone please correct it so the OP gets what he needs:
i dont think a 96 HX came with a D15Y5. if im not mistaken they come with a D16Y5. i mean, you probably just made a typo, but try to get your info correct so that you can be helped more easily.
anyway, i think it may be able to fit since its from a D-series going onto a D-series, but that doesnt necessarily mean that it is a perfect swap. the IACV connectors maybe different, etc.
Old Sep 24, 2008 | 07:53 PM
Default Re: intake swap question (Apotheosis)
hahaha whoops, i meant d16y5 . and so will wiring be different? and any hp gain?
Old Sep 24, 2008 | 08:06 PM
austinkli's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryanevansoh &raquo;</TD></TR><TR><TD CLASS="quote">hahaha whoops, i meant d16y5 . and so will wiring be different? and any hp gain?</TD></TR></TABLE>
wiring should be the same. any hp difference would be minimal
Old Sep 24, 2008 | 09:00 PM
Default Re: intake swap question (austinkli)
so would it even be worth it to put it on?
Old Sep 25, 2008 | 08:15 AM
Apotheosis's Avatar
theyr pretty much the same, which means if you do gain any power at all, you wont even be able to feel the difference. id say just leave the stock one on it and save yourselves the work swapping them.
Old Sep 25, 2008 | 05:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apotheosis &raquo;</TD></TR><TR><TD CLASS="quote">theyr pretty much the same, which means if you do gain any power at all, you wont even be able to feel the difference. id say just leave the stock one on it and save yourselves the work swapping them. </TD></TR></TABLE>
ok thanks
GuapoChapo
Aug 31, 2018 08:21 AM
blackjackEG
34
Dec 13, 2006 06:39 PM
RH-DTeg
10
Jun 6, 2005 03:14 AM
deesracer
May 6, 2004 10:56 AM
JDM_EK3
17
Dec 5, 2003 08:09 PM
