How to pull codes on swapped civic
Old Sep 24, 2008 | 12:48 PM
jimmy o.'s Avatar
Default How to pull codes on swapped civic
My freind has a swapped 88 hatch with a b16A2 so its OBD1 it has a pherable.net ecu i just want to know how i could pull codes on it because the check engine light is on??
Old Sep 24, 2008 | 01:29 PM
92VXeg's Avatar
Default Re: How to pull codes on swapped civic (jimmy o.)
at the top of the forum there is a sticky that tells you everything you need to know....
Old Sep 24, 2008 | 01:48 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: How to pull codes on swapped civic (92VXeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92VXeg &raquo;</TD></TR><TR><TD CLASS="quote">at the top of the forum there is a sticky that tells you everything you need to know....
Okay so do us a favor and you go and try and find out how he'd check the codes since the answer must be obvious in the FAQ topic, right?
*NEWSFLASH*
His car started out OBD0/Pre-OBD and thus used a blinking LED light to check codes when the key was turned into the on position.
The engine and ECU are now OBD1, which would require the use of a two prong jumper plug being jumped to then count blinking check engine lights in the guage cluster that serve as a sort of morse code with which you then see what problem codes you're throwing.
I don't know if the 88-91 chassis even has this two prong jumper since the ECU codes were intended to be read simpy, by turning the key to "on" and then reading the LED light directly on the ECU itself.
Old Sep 24, 2008 | 02:05 PM
pdiggitydogg's Avatar
https://honda-tech.com/zerothread?id=2331683
https://honda-tech.com/zerothread?id=1315469
General consensus says to ground the D4 pin
However...this thread has a guy that says otherwise...and the OP chimed in that he could check the cel...
https://honda-tech.com/zerothread?id=1619240
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef92b &raquo;</TD></TR><TR><TD CLASS="quote">
wrong
the D4(service check connector)(Brown wire) has to be joined/jumpered (only when troubleshooting codes, adjusting ignition timing, etc.) with the Green/White wire which is a "floating ground", common with the TPS, ECT, IAT and 02 sensors but not the chassis ground.
Gee...a little research goes a looooong way, doesnt it? Searched for a few mins, got exactly what you needed. Neat.
Old Sep 24, 2008 | 03:34 PM
92VXeg's Avatar
he has the obd1 ecu and harness correct? well thenthe thread tells you how to use the jumper
Old Sep 24, 2008 | 03:57 PM
.....It doenst say he has the obd1 wiring harness. It'd be wiser to assume he is using a jumper harness...which, wouldnt have the 2pin jumper.
Old Sep 24, 2008 | 04:17 PM
jimmy o.'s Avatar
we grounded off some yellow wire in the engine compartment the check engine light went off now the tach dosent work and when you turn the key on only the brake light on the dash comes on?? checked all the fuses
Old Sep 24, 2008 | 04:19 PM
jimmy o.'s Avatar
yeah it has some ghetto wiring harness the worst ive ever seen VTEC dont work etheir i think this harness is garbage
Old Sep 24, 2008 | 10:39 PM
92VXeg's Avatar
oooo ok yea i have no idea how to check it then...i would check the links form the other post. But someone correct me if im wrong but i say vtec will not work if you have a cel
Old Sep 25, 2008 | 04:04 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (92VXeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92VXeg &raquo;</TD></TR><TR><TD CLASS="quote">oooo ok yea i have no idea how to check it then...i would check the links form the other post. But someone correct me if im wrong but i say vtec will not work if you have a cel</TD></TR></TABLE>
Well some codes will disable VTEC, especially if the codes themselves are being thrown because the VTEC doesn't work.
Some codes such as oxygen sensor, IAT, and fuel supply don't usually affect VTEC.
Other codes such as TDC, CYP, MAP, TPS, VSS, etc. will certainly disable VTEC and in the case of distributor related codes (TDC/CYP/CKP) the engine sometimes won't rev over 3500rpm or so.
greenvr4
Jan 16, 2008 12:43 PM
zemogregor
Nov 12, 2007 07:19 PM
Quade
Nov 24, 2005 12:15 PM
BseriesHatch
Sep 15, 2004 08:46 PM
civicsport
Dec 26, 2002 09:41 AM
