Engine Heat...???--Smog Test
Old Jul 26, 2002 | 12:19 PM
ITR#00-1077's Avatar
Default Engine Heat...???--Smog Test
Last week my brother took his 94 GSR in for a smog check and he didn't pass.... there are 3 tests and he pass 2, but not the important one--the emissions... he took the car back a couple of days ago and the mechanic said that it had to do something with his pistons and what not.... and something about the cooling system or radiator not pushing coolant through the motor... and his engine bay is usually hot after a drive.... I know all engines get hot, but his is really hot, but his temp gauge is normal though... I need help... I can scan the emission tests results if someone can help....
Old Jul 26, 2002 | 12:28 PM
R0476's Avatar
Default Re: Engine Heat...???--Smog Test (ITR#00-1077)
Huh? Pistons? Not enough coolant through the radiator/engine block? Time for a new mechanic, he probably meant the cat was not hot enough.
I cant tell by not looking at the specs but have your brother run the hell out of his car right before he goes in again.
Old Jul 26, 2002 | 12:33 PM
Default Re: Engine Heat...???--Smog Test (R0476)
I understand that part of it though... where you run the car first before taking it in.. and that's what my brother did the second time around... he took it on the freeway before taking it back and that's when the mechanic told him that stuff... and telling him that it'll cost around $150 for him to diagnose the problem... but I'll scan his emissions test and post it up soon.... and by the way... are you a mechanic of some sort...??? Just curious.... just wanna get a sense of what's going on here with his car.... thanks...
grungefork
27
May 3, 2015 04:07 PM
akacoke
12
Dec 2, 2011 11:35 AM
sohc_freak
Jun 14, 2006 11:38 PM
asianboii83
Jan 19, 2006 02:57 PM
Sohc Driver
Mar 1, 2003 01:01 PM
