Clear coat yellowed out?
Old Sep 23, 2008 | 08:11 PM
Mrmatt3465's Avatar
Default Clear coat yellowed out?
Hey there.
Ok so I rattle can painted my bumper. I was very pleased with the turnout. The color matched pretty much right up. The problem I ran into is that the bumper was not as shiny as the rest of my car. I was told I didn't clear it heavy enough. I decided to try and reclear it.
The steps I took to reclear it was
-wash it
-wet sand it [2k grit] [was told that was wayyyy to soft afterward]
-wash it
-apply clear coat [3 coats]
The following morning the bumper looked sorta yellow. Not white at all. I was kinda saddenned =/.
What should I do to fix this? Should i just start over, prime, paint, and clear?
I was also told I should sand with 400 dry, wash it, paint it, then clear it.
What are my best options?
Thanks!
Matt
Old Sep 24, 2008 | 05:06 PM
Rukusmasta2's Avatar
Default Re: Clear coat yellowed out? (Mrmatt3465)
600 wet, wash, paint, clear.
Old Sep 25, 2008 | 04:43 AM
DC2.2_GSR's Avatar
Default Re: Clear coat yellowed out? (Rukusmasta2)
to be perfectly honest, the only way to really fix it is to get it painted properly with automotive paint.
the yellowing might be soimething as simple as you have too many coats on it. you'll see yellowing over white very easily.
the problem you're going to run into is the fact that rattle can paint is not durable because it is not catalyzed. "real" clear coat is. it just means that the real clear hardens while the rattle can just dries. there's no chemical reaction taking place with rattle can paint/clear dries. basically after even a few days the spray paint might start looking hazy or dull, no matter how many coats you put on.
Old Sep 25, 2008 | 09:05 PM
Mrmatt3465's Avatar
Default Re: Clear coat yellowed out? (DC2.2_GSR)
I used "Import auto touch up spray". The paint did look kind of matted. It was too flat. It wasn't shiny enough. I got picky and messed it up. I think I'll probably end up wiping it clean, primer, sand, primer, paint, clear. It looked real good until I tried to re clear it. I put a pic of my cousins bumper in this thread: https://honda-tech.com/zerothread/2394280 He cleared his much differently then mine. His was more experimental. =P
skateboard c
Jun 15, 2008 11:09 AM
Teg_Your_It
Aug 19, 2006 11:55 AM
nek0
Jul 19, 2003 06:27 AM
djay86
Sep 23, 2002 03:59 PM
Phat Corolla
Aug 20, 2001 08:10 PM
