Remove side skirts
i have a 94 ex coupe, and i would like to know the right way to remove/ put on side skirts without braking the clips. also what years are sideskirts interchangeable? what about hatch skirts fitting coupes?
thanks in advance
thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Decaf »</TD></TR><TR><TD CLASS="quote">i have a 94 ex coupe, and i would like to know the right way to remove/ put on side skirts without braking the clips. also what years are sideskirts interchangeable? what about hatch skirts fitting coupes?
thanks in advance</TD></TR></TABLE>
About the side skirts being removed I think it the same prosses as an accord.
https://honda-tech.com/zerothread/2378549
As for the side skirts fitting I not sure. I think its only 92-95.
1. unscrew two screws from the front wheel well.
2. unscrew plastic screws from the bottom of the sideskirts.
3. pull sideskirt towards the rear wheel.
4. remove white plastic clips.
*to put it back you have to put the white clips on the sideskirts first. it should push right in.
when it comes to interchangeable:
92-95 coupe to 96-00 coupe.
92-95 4dr to 96-00 4dr.
92-95 hatch to 96-00 hatch.
they are all different sizes.
when putting a 96-00 sideskirts on a 92-95 you will NOT be able to use all the white clips [about 3] but ALL the plastic screw will screw under the sideskirts.
my2ndaccord
Sep 16, 2010 10:09 AM
