Vtec Question from a DSM
Old Jul 26, 2002 | 10:22 AM
VTEC KILLA's Avatar
Default Vtec Question from a DSM
Hey, not here to start anything just to get a good answer. I drive a DSM 97 Eclipse RS n/a unfortunately. but anyway...I used to drive a civic btw. To my question...ive got a friend who drives a 94 Accord EX (i think). At any rate...shes been complaining of the car being sluggish at about 40 miles per hour. Now...shes got the SOHC VTEC engine. I drove her car around to see if i could feel the sluggishness and I didnt feel anything. I got outta the car when i parked it on a level surface and checked her engine oil...she had zero showing up on the dipstick. heres the question of the day...would LOW oil cause the VTEC to engage improperly and translate into sluggishness? Thanks...please IM me at Brohymn411 on aol if u know anything about it. Thanks
joe
Old Jul 26, 2002 | 10:24 AM
KGAccord's Avatar
Default Re: Vtec Question from a DSM (VTEC KILLA)
Yes VTEC needs proper oil pressure.
Old Jul 26, 2002 | 10:31 AM
VTEC KILLA's Avatar
Default Re: Vtec Question from a DSM (KGAccord)
k thats what I figured. thanks
joe
Old Jul 26, 2002 | 04:29 PM
Razor's Avatar
yes oil level and pressure are only a small part of the whole vtec process, you also need to have the car under a correct amount of load and correct engine temperature.
Old Jul 27, 2002 | 06:07 AM
Gennady's Avatar
New User
Default Re: Vtec Question from a DSM (Razor)
From what I can remember, these are some prerequisits for VTEC to engage:
RPM
<10mph
Proper engine temp
Proper engine oil pressure
Proper amount of engine oil
There are more, but I just cant remember them all now.
Old Aug 3, 2002 | 02:32 PM
Brian_92GSR's Avatar
New User
Default Re: Vtec Question from a DSM (Wont be beat)
You have to be moving at a certain speed (meaning you have to be in gear), the coolant must be up to a certain level, and there must be at least 55 psi of oil pressure (which should happen a bit before 3000 rpm). If all of those conditions are met it will turn on at the set RPM crossover point, which is probably above 5000 on that engine.
Old Aug 4, 2002 | 09:35 AM
SOHCmycord's Avatar
New User
Default Re: Vtec Question from a DSM (dohctwinn1)
you dont need to be in gear to hit vtec!!!!!
Old Aug 4, 2002 | 01:01 PM
ArchAngel Sabastian's Avatar
New User
From what I can remember, these are some prerequisits for VTEC to engage: RPM <10mph
hmmmmm
ahenscheid
Jan 23, 2012 06:44 PM
blacktibby07
May 14, 2011 11:12 AM
TheAccordGuy
Dec 27, 2006 07:51 AM
GSR_ITM
Apr 16, 2005 09:37 PM
Luserkid
Dec 28, 2002 09:53 PM
