idle and acceleration problems
Old Sep 20, 2008 | 06:35 PM
cloudconnected85's Avatar
Default idle and acceleration problems
ok idle bouces from 1500 to 2000 rpms constantly iac valve does not rise or lower it when i disconnect it. and it wraps out every gear way too fast.
Old Sep 20, 2008 | 09:57 PM
civicjoe's Avatar
Default Re: idle and acceleration problems (cloudconnected85)
I think u said it yourself IACV
Is
your clutch slipping?
Old Sep 21, 2008 | 12:03 AM
gsxr1k05's Avatar
to find out if its your iacv that needs to be cleaned (and most all of them do) cover the hole in the throttle body with your finger, and if the surging goes away, you need to remove it and clean it per the DIY in the FAQ. and i agree with civicjoe about the clutch. when you go to accelerate from a stop, what is the rpm at to get the car moving? if its anything over 2 grand you should think about checking your clutch.
Old Sep 21, 2008 | 01:20 AM
Default Re: (gsxr1k05)
don't think its my clutch it just wraps out realy fast i found something similiar on here that said it could be a vacuum leak i'm hoping it is. the clutch should be fine it was when i took the engine out 4 days ago
Old Sep 21, 2008 | 07:46 PM
Default Re: (cloudconnected85)
found it was a huge vac leak at the intake manifold gasket
brian323is
Mar 15, 2010 11:17 AM
thechamp657
Oct 12, 2007 02:23 AM
01_prelude
Dec 12, 2005 06:27 PM
hondaracing1
May 15, 2004 09:39 PM
J-g-D-s-M-r
Sep 3, 2003 01:44 PM
