piston swap
Old Sep 20, 2008 | 03:12 PM
gibson_standard_sg's Avatar
Default piston swap
I have a d15z1 vTech and a dohc d16zc and i wanted to bore the z1 to fit the zc pistons for higher compression and do a mini me swap with a z6 vTech head on the z1 but i need to know if the piston rods from the zc will work with the z1 crank and block.
Old Sep 20, 2008 | 03:16 PM
sleepingciv's Avatar
Default Re: piston swap (gibson_standard_sg)
i dont think they will cause of the crank size.
you be good though finding a d16a6 block then using the zc stuff in that
Old Sep 20, 2008 | 03:33 PM
Default Re: piston swap (sleepingciv)
why use a a6 instead of turning the z1 into a d16z6?
Old Sep 20, 2008 | 03:54 PM
ya the cranks wont fit.
also i did a compression check with a a6 block with the z6 internals and pistions. and its only 9.1 compression. maybe get a d15b7 block then youd be at higher compression
Old Sep 20, 2008 | 03:55 PM
http://www.knology.net/~jediklc/dcalc.htm
Old Sep 20, 2008 | 04:09 PM
alright man i cant figure out what the hell i wanna do with my two engines i have two hondas and i planed on using both engines but i dont know whats best for each. i have a carbed 87 civic automatic with the slow d15a2, and a 91 civic ex Manual with the d15b2, what would you do with what ive got? i want some more options.
Old Sep 20, 2008 | 04:12 PM
i perferably want to turbocharge the jdm
Old Sep 20, 2008 | 04:20 PM
turboing the dohc zc is a good choice, can hold like 6 psi safley i would would go that route
Old Sep 21, 2008 | 03:39 PM
alright somebody needs to tell me how this website works, and what the light bulbs and stuff means, i can only have 5 posts every 24 hrs, why? but anyway im planning on turboing my dohc d16zc but i would like to know if i should use the pm7 pistons and rods(9.5:1) or replace them with something better, also i would like to know what the best camshafts would be to use in the jdm.
josh909
10
Mar 12, 2010 07:58 AM
alx_90ef
Sep 29, 2009 11:35 AM
jawsiiv
19
Jun 9, 2009 08:52 PM
CR3X
Jun 25, 2008 11:26 AM
crx si 2004
Jun 29, 2004 05:25 AM
