triying to rase my comperetion
i herd that you can put DOHC zc pistons in a d16y7 block? is that true?im runing a z6 head on the block will the valvs cleer and not hit? thanks
MiG-21 superfan
Re: triying to rase my comperetion
if you are talking about p29/pm7 pistons and not flat pg6b pistons from 86-87 d16a1...
yes, they will physically work, but you will need swap to obd1 and run the proper tuneable ecu to run such a combination.
with the y7 head you will be in the mid-12's static compression.
put this in your favorites - http://www.knology.net/~jediklc/D.htm
crxtreme27
05-01-2003 11:19 AM
