idle air control valve problem.
Old Sep 20, 2008 | 12:38 PM
96teggynonVtec's Avatar
Default idle air control valve problem.
So last night my check engine light came on. Car would stall anytime i was below 1krpms. I pulled the codes from Hondata and got code 14. idle air control valve. So i took it out, cleaned it with brake cleaner and put it back on. Car ran good for 5 min. After giving it full throttle and going full boost the light came back on and once again i cant get full boost. The car runs on 110 octane Leaded gas (tuned) So i was wondering why the light would come on again after running good for 5 min. I will probably take it off tomorrow again and either put my spare on on or clean this one again. Any suggestion on what else it can be?
Old Sep 20, 2008 | 12:44 PM
BoSox46GSr's Avatar
Default Re: idle air control valve problem. (96teggynonVtec)
The codes don't lie... make sure that the lines are hooked up to the IACV, and you have no leaks. If that checks out, I would put the spare one on that you have. I believe coolant flows to it through one of the lines, if you are not getting a sufficient amount of coolant, it will cause your idle to surge normally. But in your case, it doesn't sound like that's the problem, but it's something to think about.
Old Sep 20, 2008 | 02:22 PM
lance_dc2's Avatar
how much boost are you running? check the seal between intake manifold and iacv..... if you are running alot of boost you could have cracked the diaphram inside the iacv... try and replace whole unit.
Old Sep 20, 2008 | 10:22 PM
^21lbs... u mean the rubber seal in the IAVC?
Old Sep 21, 2008 | 03:26 PM
is there a way to adjust the iacv? One looks to be in the closed position and the other in an open position. What possition should it be in.
Modified by 96teggynonVtec at 8:03 PM 9/21/2008
Old Sep 21, 2008 | 04:18 PM
chocolatesk8er10's Avatar
Default Re: (96teggynonVtec)
i got a IACV only used for 2 days on an ls, let me know if you want it
http://i70.photobucket.com/alb...9.jpg
Old Sep 21, 2008 | 07:01 PM
^pm'd
Anywas i started the car up with my second one and everything was good. I let the car idle for 10 min and took it out for a drive. Gave it some gas in second maybe half boost and once again CEL comes on and car wont idle and stalls. ANy ideas?
Old Sep 22, 2008 | 08:50 AM
anyone?
Old Sep 22, 2008 | 10:18 AM
so once again i start it and it idles fine. Go for a drive an Cel comes on... same code. Anyone know why the coolant lines are there?
Old Sep 22, 2008 | 10:49 AM
any chance its the fast idle thermo valve?
Modified by 96teggynonVtec at 7:02 PM 9/22/2008
Old Sep 23, 2008 | 12:09 PM
no one knows anythin on iacv's?
Old Sep 24, 2008 | 01:06 PM
Pandor's Avatar
The coolant just passes through the bowl on the bottom.
A.f.a.i.k it's only there to heat the eacv during winter time (cold air might freeze it up).
I have mine disconnected and the coolant bypassed.
Since you tried 2 eacv's with the same result, I wouls suspect bad wiring/connector or your ecu going bad.
Check out the serivce manual on how to diagnose the problem.
Old Sep 24, 2008 | 04:23 PM
thanks for the reply. i will try and check my connector and wiring tommorow.
Old Sep 25, 2008 | 10:09 AM
well i sprayed the connector with electric cleaner and voula. Car starts up. hits full boost and everything.
thanks guys
crazyz250
27
Feb 17, 2021 07:25 PM
frostykue
Mar 28, 2013 08:29 PM
jtornado
Jan 4, 2007 02:26 PM
Norrod
Nov 18, 2005 08:16 AM
ECICivic
12
Mar 4, 2005 07:15 PM
