Best way to clean valves? I have them out of the motor already
Old Sep 19, 2008 | 11:18 AM
vtecn8ive's Avatar
Default Best way to clean valves? I have them out of the motor already
I'm in the middle of changing my valve seats and wanted to know a good way for removing the carbon build up.
I had the head degreased when they resurfaced it, but i had the valves in. Just saying .
I already have the valves out and am wondering what the best method for removing the carbon build up?
I'm debating break cleaner, oven degreaser?
-Shane
Old Sep 19, 2008 | 12:08 PM
Fkned's Avatar
Default Re: Best way to clean valves? I have them out of the motor already (vtecn8ive)
Glass bead is the fastest way as long as you cover the stems so they don't get hit.Then stick in a lathe or drill press and use scotchbrite with some wd40 to take the bead surface away and polish the heads.
Are you doing the machine work or a shop I would think they would have their own way of cleaning.
Old Sep 19, 2008 | 12:23 PM
redsolturbo's Avatar
Default Re: Best way to clean valves? I have them out of the motor already (Fkned)
swarfega metal cleaner.
mix a 50/50 solution (swarf and water) stand the valves in it overnight.
take em out, most carbon will wipe away, some more stubbon bits will come off with a toothbrush type item.
jobs done, clean valves, still coated in oem black anti friction stuff etc.
Old Sep 19, 2008 | 12:38 PM
vtecn8ive's Avatar
Default Re: Best way to clean valves? I have them out of the motor already (redsolturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redsolturbo &raquo;</TD></TR><TR><TD CLASS="quote">swarfega metal cleaner.
jobs done, clean valves, still coated in oem black anti friction stuff etc.</TD></TR></TABLE>
any in the US?
Old Sep 19, 2008 | 12:53 PM
Skunk2Brian's Avatar
Good old fashioned wire brush wheel works wonders, just stay away from the valve stem itself.
Old Sep 20, 2008 | 12:39 PM
Default Re: Best way to clean valves? I have them out of the motor already (Skunk2Brian)
no idea i work in a motor factors and get this stuff at company cost (ie: virtually free!)
im sure they sell it in the u.s or you guys have an equivalent of it, its basically metal cleaning acid ( a mild one) DONT use it on alloy heads though , only on inconnel/stainless etc
Old Sep 24, 2008 | 05:41 AM
guymosiris's Avatar
Brake cleaner and brush
NocTurNalFX
Mar 27, 2011 12:09 PM
vtecn8ive
Sep 19, 2008 01:23 PM
boomersz
Apr 9, 2007 11:35 AM
85
Aug 11, 2006 10:05 PM
jdub db8
May 4, 2004 08:32 PM
