How to clean valves? I have the valves out already.
I'm in the middle of changing my valve seats and wanted to know a good way for removing the carbon build up.
I had the head degreased when they resurfaced it, but i had the valves in. Just saying .
I already have the valves out and am wondering what the best method for removing the carbon build up?
I'm debating break cleaner, oven degreaser?
-Shane
-Shane
Re: How to clean valves? I have the valves out already. (vtecn8ive)
you could always just buy new ones, they're relatively cheap.
but carb cleaner would probably do that trick.
Re: How to clean valves? I have the valves out already. (obuhmyuh)
i use a brass wire wheel very light will not scratch and does the job carb cleaner will work if there not that dirty
Re: How to clean valves? I have the valves out already. (Dkober101)
i sprayed brake cleaner in a shot glass, put a valve inside it and then sealed it up in a zip-loc bag. I'm going for a run so i'll check back on it later to see if it comes off easier.
maybe brake cleaner was not the right stuff to get?
vtecn8ive
09-24-2008 05:41 AM
