Cruise control not working!!
Old Sep 18, 2008 | 09:22 PM
Bob Dole!'s Avatar
Default Cruise control not working!!
I press the set button and the cruise control light doesn't come on, nor does it maintain speed. The light on the cruise button also doesn't come on when you press it, however that stopped working long before the cruise stopped working. Looked for the fuse and it seems there is no cruise control fuse under the dash or in the engine bay. By the way this is for a 93 del sol with the d16z6. Any info/help would be appreciated!!! Sorry for the novel!
ISSUE RESOLVED:
The problem was the switch on the clutch pedal. It didn't make good contact with the clutch pedal. Adjusted it and worked flawlessly.
Old Sep 18, 2008 | 09:28 PM
civicjoe's Avatar
Default Re: Cruise control not working!! (Bob Dole!)
I'd get out the multimeter and check that's it's getting power.
Old Sep 18, 2008 | 09:31 PM
Bob Dole!'s Avatar
Default Re: Cruise control not working!! (civicjoe)
I was afraid of that response! Seeing how I don't happen to have a multimeter!
Old Sep 18, 2008 | 09:55 PM
civicjoe's Avatar
If you do a lot of diagnosing and such it's a great investment. Get a digital one for 30-40 bucks at radioshack, I was hesitant about getting one but's it's one of my favorite toys...umm...tools. Otherwise I don't know what to tell you, I would say it's either:
A) not getting power
B) Bad component
Multimeter will tell you which.
Old Sep 18, 2008 | 10:12 PM
Bob Dole!'s Avatar
Well shucks! I guess I'll double check all the connections and if that doesn't work, break down and buy a multimeter!
Old Sep 18, 2008 | 10:44 PM
civicjoe's Avatar
I'm not sure if any of the connections are exposed as I've never had stock cruise control before but make sure you keep a good eye out for corrosion.
Old Sep 19, 2008 | 04:43 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Make sure you've got vacuum going to the cruise. It absolutely won't work without it. Also check the throttle cable - there's one that runs from the cruise to the back of the gas pedal.
Old Sep 19, 2008 | 01:02 PM
Bob Dole!'s Avatar
Default Re: Cruise control not working!! (Vindicator9000)
It has the electronic cruise same as 92-95 civics, not the vacuum system the 96-00 have. I thought about the throttle cable too, but I would think the light would at least come on if that was the case, plus when I operate the cruise cable by hand, the throttle body opens and closes just like it should. Man I wish it was as simple as the cruise cable!
Old Sep 19, 2008 | 01:32 PM
wow, my bad. I thought they all had vacuum cruise.
Good luck.
Old Sep 19, 2008 | 08:11 PM
Bob Dole!'s Avatar
Thanks! Any more suggestions before I go out and get a multimeter?
Old Sep 20, 2008 | 12:13 PM
Bob Dole!'s Avatar
Bump for more suggestions!
Old Sep 20, 2008 | 08:53 PM
Bob Dole!'s Avatar
Suggestions?
Old Sep 20, 2008 | 09:23 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
I know here it doesn't mention a fuse:
https://honda-tech.com/zerothread?id=1966666
But I'd pull each one looking for a bad fuse. The fifth gens use fuse 12 for cruise control.
Old Sep 21, 2008 | 12:32 AM
Mr. Em1's Avatar
maybe the module itself went bad, if you can borrow one, try and test it if not try and get that multimeter and see if it is getting power. good luck
Old Sep 21, 2008 | 07:45 PM
Bob Dole!'s Avatar
Default Re: FV-QR (NOFX)
I noticed in the thread nofx posted fuse #24 is the cruise fuse in a del sol. However my cluster and all that still works and the fuse was not blown. In fact no fuse was was blown in the whole fuse panel! So its likely that its the module itself. I'll likely get a multimeter tomorrow and find out for sure.
eskudo12791
Jun 14, 2010 07:26 PM
mac_24_seven
Aug 31, 2009 09:15 AM
Sweetsystem
Aug 26, 2008 01:58 PM
Juan_Mitosis
Jun 19, 2008 11:13 PM
Hairy Gorilla
Feb 12, 2005 02:31 PM
