ROD KNOCK question
Old Sep 18, 2008 | 08:48 PM
Zerotls's Avatar
Default ROD KNOCK question
My D16 starting makeing a loud knocking noise at low to midrange RPMs. I checked and readjusted the valve lash so its not valve noise. is there a way to know if its rod knock or someting in the block without takeing it apart?
Old Sep 18, 2008 | 08:52 PM
jimmy o.'s Avatar
It sounds like you got a knock and if it is i know it sucks i just had mine rebuild but mine was messed up when i bought it. You have 2 options rebuild your motor or stick in a d15b in it ( which i have one btw lol) it cost me bout 865 to rebuild the longblock so its your choice what to do next
Old Sep 18, 2008 | 08:53 PM
jimmy o.'s Avatar
no wait 3 options or swap it to b-series
Old Sep 18, 2008 | 09:01 PM
Zerotls's Avatar
Default Re: ROD KNOCK question (Zerotls)
GOD damm it. its a built bottom end and a turbo kit i gota get it rebuilt, any one know a reputable engine builder in the SOCAL area.
Old Sep 18, 2008 | 09:03 PM
Nikhil loves VTEC's Avatar
check your distributor
Old Sep 18, 2008 | 09:10 PM
civicjoe's Avatar
Default Re: ROD KNOCK question (Nikhil loves VTEC)
How the [freak] would it be the dizzy? I don't think you know what your talking about...
Old Sep 18, 2008 | 09:26 PM
jimmy o.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zerotls &raquo;</TD></TR><TR><TD CLASS="quote">GOD damm it. its a built bottom end and a turbo kit </TD></TR></TABLE>
Well damn son how many psi did you have on it!?!?!?!
Old Sep 18, 2008 | 09:32 PM
jasony0630's Avatar
76.26.106.124
If it's knocking....well, there's no other way to put it, but you're [freak]ed.
Might as well start ripping that bitch apart and rebuilding.
Before something worse happens.
Old Sep 18, 2008 | 09:39 PM
Zerotls's Avatar
Default Re: (jasony0630)
it was tunned for 17psi but most of the time i had it on 15, but i cant think of anything that would have caused it. I didnt build the bottom end so i guess the build was bad. any one know a reputable shop in San Diego that i can take it to.
Old Sep 18, 2008 | 09:46 PM
Zerotls's Avatar
Default Re: (Zerotls)
ohh well gota pay if you wanna play i will post some pics ... just becasue i have never shared them on the forums before
http://www.flickr.com/photos/3...96619/
http://www.flickr.com/photos/3...25390/
Old Sep 18, 2008 | 09:48 PM
civicjoe's Avatar
GL on the rebuild man
Old Sep 18, 2008 | 09:53 PM
jasony0630's Avatar
76.26.106.124
It doesn't matter if it was perfectly tuned or not.
Motors all have different lifespans. One B16 may be a factory freak and last for [freak]ing ever untuned at say 14psi. And another B16 that's been fully built and tuned for 14psi may take a **** after 1000 miles of boost. You never know. Just like metals, even if they have the same atomic properties, they are never the same.
Have fun rebuilding that bitch.
And do it right too!
Always check your clearances/tolerances and make sure they're all to spec.
Old Sep 18, 2008 | 10:03 PM
Zerotls's Avatar
i would do the build myself but i start school on Monday so i don't have time. i gotta bite the bullet and take it to a shop OUCH, but if it costs more than 4k to fix at the shop i am just gonna swap in a B18. thanks guys.
Old Sep 18, 2008 | 10:16 PM
jasony0630's Avatar
76.26.106.124
To be honest, building a motor is not hard at all.
You just gotta know your clearances (Rod bearings, Piston rings, main bearings, etc..).
RevrsOne
Other Make Vehicles
Aug 21, 2012 06:50 PM
preludeboybmw
Sep 29, 2010 04:21 PM
jdmboy96
18
Apr 25, 2009 11:16 AM
92b16si
15
May 1, 2007 07:08 AM
SickIntegraWon
Apr 13, 2007 12:59 PM
