My car doesnt have an oil catch can???
Old Sep 18, 2008 | 06:50 PM
jdmvtecej2's Avatar
Default My eg coupe doesnt have an oil catch can???
how come my coupe is running fine without an oil ctach can and oil isnt leaking???? dont i need one??? and what is it for??
Old Sep 18, 2008 | 07:24 PM
Frickr's Avatar
Default Re: My eg coupe doesnt have an oil catch can??? (jdmvtecej2)
why would you need one? your oiling system should be a closed system as it is. got a plug on the bottom to drain it and a cap on top to fill it. in the mean time the oil doesnt leave your block unless if your running a turbo
Old Sep 19, 2008 | 03:56 AM
jdmvtecej2's Avatar
so why do hondas come with them stock from factory cause my other eg had one and i can see the hoses for the cannister
Old Sep 19, 2008 | 04:02 AM
00b20vtecoupe's Avatar
ppl put them on aftermarket b/c they blow oil out of their valve cover where the breather is... i just ran a hose on it to the ground. i think its just so u dont blow oil on ur motor... i didint think they came stock but i may be wrong
Old Sep 19, 2008 | 08:03 AM
honda_joe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtecej2 &raquo;</TD></TR><TR><TD CLASS="quote">so why do hondas come with them stock from factory cause my other eg had one and i can see the hoses for the cannister</TD></TR></TABLE>
You sure you're not thinking of the charcoal canister? That looks similar to a oil catch can, but serves a completely different purpose.
Old Sep 19, 2008 | 09:52 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: My eg coupe doesnt have an oil catch can??? (honda_joe)
^^^that's what I'm thinking. I could be wrong, but I've never seen a OEM catch can.
Old Sep 19, 2008 | 10:09 AM
honda_racing101's Avatar
Yeah, youre thinking of a charcoal canister..
Old Sep 19, 2008 | 10:26 AM
i drive a honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtecej2 &raquo;</TD></TR><TR><TD CLASS="quote">how come my coupe is running fine without an oil ctach can and oil isnt leaking???? dont i need one??? and what is it for??</TD></TR></TABLE>
piston rings arent 100% round, and solid
gas/vapors blow through the gaps., and create postive pressure in the oil pan. without some way to release that presure...... your oil pan seal, or rings/ something has to give. and itll create a leak.
honda uses a closed loop system meaning they just through it back into the intake tract, to burn it.
great fr emissons not great for performance,
some add more, clean out the valve cover, use AN fittings, braze/gtaw female fittings on to them so they are removable.
have fun
so what these kids are doing is removing the charcoal cansiter, and intake feed lines, making/modifying plugs, to introduce it into a cansiter like device with a filter and drain on the bottom.
filter lets vapors out (breather) drain lets blown out oil, and soot out.
Old Sep 19, 2008 | 01:55 PM
VFC CEO's Avatar
Default Re: My eg coupe doesnt have an oil catch can??? (Vindicator9000)
it might be the canister. withch is for vapors. .
oil catch can only goes in TURBO charged vehicles.. turboed cars dispence a lot of oil blow by.. i had an srt4. they do it A LOT...LOL.. just my .02 cents. .
jit01
10
Oct 29, 2007 10:21 PM
ThrowSomeDs
Oct 30, 2006 05:06 PM
Squallie
18
Sep 26, 2005 03:32 PM
Chris F
22
May 31, 2005 03:50 PM
grandmasterflex
Mar 16, 2004 03:49 PM
