fuel pump not turning on
Old Sep 17, 2008 | 12:09 PM
redferio's Avatar
Default fuel pump not turning on
no spark no fuel ..pump is not turning on...need help asap
Old Sep 17, 2008 | 12:19 PM
taztwnpa's Avatar
Default Re: fuel pump not turning on (redferio)
check you main fuse
Old Sep 17, 2008 | 01:12 PM
SwapsRUs93's Avatar
do u have a check engiine lite on and if it is does it just stay on all the time?
Old Sep 17, 2008 | 01:15 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redferio &raquo;</TD></TR><TR><TD CLASS="quote">no spark no fuel ..pump is not turning on...need help asap
check the main relay.
Old Sep 17, 2008 | 02:15 PM
lshatch98's Avatar
main relay
Old Sep 17, 2008 | 02:38 PM
redferio's Avatar
Default Re: (lshatch98)
I checked the main relay...switch dizzy, ecu, main relay, fuel pump..i checked all the grounds....
I forgot to mention that the ecu fuse kept poppoing until i found the one ground lose by the fan swtich...
Modified by redferio at 6:49 PM 9/17/2008
Old Sep 17, 2008 | 02:54 PM
redferio's Avatar
Default Re: (redferio)
please help
Old Sep 17, 2008 | 04:20 PM
-[95cxhatch]-'s Avatar
how did you check the main relay? it really sounds like your main relay is bad...
Old Sep 17, 2008 | 04:21 PM
what year is your car? etc...
Old Sep 17, 2008 | 05:23 PM
jdmdikk's Avatar
Default Re: (-[95cxhatch]-)
i say check theem groundz
Old Sep 17, 2008 | 06:36 PM
redferio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -[95cxhatch &raquo;</TD></TR><TR><TD CLASS="quote">-]how did you check the main relay? it really sounds like your main relay is bad...</TD></TR></TABLE>
93 civic coupe ex..
i switched it..
Old Sep 17, 2008 | 06:42 PM
redferio's Avatar
I found a bad fuse under the dash #24 15amp...and the ecu fuse keeps popping
Old Sep 18, 2008 | 07:08 AM
redferio's Avatar
Old Sep 18, 2008 | 07:30 AM
redferio's Avatar
Default Re: fuel pump not turning on (SwapsRUs93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwapsRUs93 &raquo;</TD></TR><TR><TD CLASS="quote">do u have a check engiine lite on and if it is does it just stay on all the time?</TD></TR></TABLE>
yes it does.....9 and 10 are the codes
Old Sep 18, 2008 | 07:37 AM
redferio's Avatar
?????need head
Old Sep 18, 2008 | 07:39 AM
crick_james's Avatar
is your transmission ground wire hooked up ? if it is not then your car will not start, and nothing will turn on besides the headlights wipers and radio
Old Sep 18, 2008 | 08:00 AM
redferio's Avatar
Default Re: (crick_james)
yes i checked that already..
redferio's Avatar
maybe i should put new ground wires.
Old Sep 18, 2008 | 08:03 AM
redferio's Avatar
now only the ecu fuse keeps blowing
Old Sep 18, 2008 | 11:42 AM
redferio's Avatar
Old Sep 18, 2008 | 12:54 PM
Roi's Avatar
Roi
try using another ecu, i had the same problem. i replaced all these parts and it just turned out that the ECU went bad. so you should try.
Old Sep 18, 2008 | 01:56 PM
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
Check the wires/grounds for these...
Old Sep 19, 2008 | 03:47 AM
redferio's Avatar
Default Re: (Roi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Roi &raquo;</TD></TR><TR><TD CLASS="quote">try using another ecu, i had the same problem. i replaced all these parts and it just turned out that the ECU went bad. so you should try.</TD></TR></TABLE>
I did that already....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -[95cxhatch &raquo;</TD></TR><TR><TD CLASS="quote">-]9 CYP - cylinder sensor
Check the wires/grounds for these...</TD></TR></TABLE>
I'll try that today
Old Sep 20, 2008 | 02:40 PM
redferio's Avatar
i got the fuel pump going and the main relay...it was the ground on the tranny that was no good....now i have no spark.....dizzy is brand new from dist. king
Phil McConkey
Feb 25, 2007 07:42 PM
boosted_soul_94
Aug 5, 2006 09:57 AM
Down Shift Motoring
Mar 11, 2006 05:32 AM
Terrible One
Jan 5, 2006 07:49 PM
DenMatic
21
Feb 3, 2004 05:51 PM
