main relay problem or fuel pump?
Old 08-03-2006, 04:59 PM
boosted_soul_94's Avatar
Default main relay problem or fuel pump?
hey i have a qeustion and im not sure if its teh main relay or the fuel pump...
ok so i drive my car around..parked it...5 minutes later i go back in..it barely wants to start and dies..then it just keeps on cranking when i turn the key like its not getting no fuel...after about 10-15 minutes of waiting i go back and try again then it starts up...
is it the main relay or the fuel pump? thanks for your help!
Old 08-03-2006, 05:13 PM
BluLude's Avatar
Default Re: main relay problem or fuel pump? (boOsted_sOuL_94)
i would check it rather than guessing, one way is to see if it doesnt start do the injectors pulse and do u get spark? Another would be to check if there is power going to the fuel pump from the main relay.
Old 08-03-2006, 05:14 PM
JDMlyfestyle's Avatar
Definately sounds like the main relay is starting to give way. id go to honda and order one before it does **** out on you
Old 08-03-2006, 05:28 PM
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Definately sounds like the main relay is starting to give way. id go to honda and order one before it does **** out on you</TD></TR></TABLE>
ok sweet..yea i will do that then..just wanted to double check..
Old 08-03-2006, 05:36 PM
dem0nk1d's Avatar
Default Re: (boOsted_sOuL_94)
yeah my car had that issue for some time. i took put the main relay pulled the outter case of it off, and heated the solder contacts on the back of the board, and added more solder... fixed worked like a champ.
Old 08-05-2006, 09:57 AM
leewal's Avatar
have same prob, main relay, factory soldering fault. pain in the ***,especially at petrol station
Domnificent
07-11-2010 10:29 AM
uszcrx
24
09-09-2006 01:05 PM
nonbox
01-30-2006 01:00 PM
Magick211
11-21-2004 03:21 PM
Steve
08-29-2001 06:38 PM
Quick Reply: main relay problem or fuel pump?
