OBD2 engine/dist/etc into OBD1 car, crank sensor questions + others.
Old Sep 16, 2008 | 07:17 PM
SovXietday's Avatar
Default OBD2 engine/dist/etc into OBD1 car, crank sensor questions + others.
Ok, putting a Y8 into an OBD1 converted CRX. Wiring wise, it's the same as putting a Y8 into an EG, so that's why I'm posting this here.
Y8/Y7 has the external crank sensor. Using an OBD2 dist, need to convert it into OBD1. Does anyone know if the OBD1 ECU (Will be tuned by me with Crome) will recognize the external crank sensor at all. IE, is everything the OBD1 computer needs in the OBD2 distributor or will I need to figure out how to wire up that external crank sensor. Everything I remember from doing an OBD2 -> OBD1 engine swap in my EK tells me I won't need to worry about the sensor, but I want to know if anyone can confirm that.
Next, does someone have the OBD2 alternator pinout handy? Also need the OBD0 pinout as well.
Also need the OBD2 - OBD1 distributur pinout if someone can link me. I am having trouble finding it.
Thanks guys, if no one knows I'll be sure to update this thread with what I find.
Old Sep 16, 2008 | 08:00 PM
94EG8's Avatar
Seagull Management
Default Re: OBD2 engine/dist/etc into OBD1 car, crank sensor questions + others. (SovXietday)
Don't worry about the CKF sensor on the Y8.
Old Sep 16, 2008 | 08:34 PM
SovXietday's Avatar
Default Re: OBD2 engine/dist/etc into OBD1 car, crank sensor questions + others. (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">Don't worry about the CKF sensor on the Y8.</TD></TR></TABLE>
Great, thank you.
Found all of the other info I needed as well. Just incase this thread is found when searched, I'll post the info I found.
Dist wiring
Alt wiring
OBD0 ------------------ OBD2
Yellow -------------- White w/Red Stripe
White w/Yellow Stripe ------------------White w/Green Stripe
Black w/Yellow ----------------Black w/Yellow Stripe
White w/Blue Stripe ------------ White w/Blue Stripe
honda2ksi
Jun 24, 2010 01:45 PM
unknownlou
Jan 25, 2006 08:51 PM
b20_ed
Nov 10, 2005 12:25 PM
k24a4kid
Jan 24, 2005 10:05 AM
BlkSIvic
Sep 1, 2004 10:12 AM
