96 Lx b16 swap
i am currently doing a b16 engine swap from a 99 si into my 98 lx. what i would like to know, is it a direct swap. Since the b16 is ob2b and the 98 lx is a ob2a, would the wiring be an issue or will everything from the si just swap over without any issues. I intend to use the obd2b ecu with the engine so i will not be converting to obd1. Thanks
Modified by Muuugen at 1:23 AM 9/16/2008
if you have the si as a donor car.. you can swap everything you need from it..
the mounts, shift linkage, wire harness..
should be a pretty easy swap..
the only thing im not sure about is the engine harness to dash harness connectors.. they might be different from obd2a to obd2b..
even still, there arent too many wires in that connector, could always make your own connector to get it to work.. or depin the dash harness connector from both vehicles and repin the si into your lx
