Have you repaired the elbow hole in your door panel?
Old Sep 15, 2008 | 06:16 PM
specoperformance's Avatar
Default Have you repaired the elbow hole in your door panel?
The drivers side inner door panel of my EK has a hole broken in the plastic of the door panel but under the fabric, not unusual after 188k. I was thinking of pulling off the fabric and fiberglassing the hole and upgrading the cloth for the insert at the same time. Has anyone repaired their door panel elbow hole?
Old Sep 15, 2008 | 06:30 PM
EJ8_Enthusiast's Avatar
nope. I just pretend its a cushion with jagged edges for my elbow to rest on.
Old Sep 15, 2008 | 06:32 PM
Default Re: (EJ8_Enthusiast)
i guess im lucky that i bought the car from a lil asian guy and my elbow is farther back then his was so mine doesnt sick in said jagged hole
Old Sep 15, 2008 | 06:50 PM
addiction2bass's Avatar
Default Re: (specoperformance)
LOL ya mines been busted since i got my 96dx for now it just feels like a cusion pad
but to fix it what i will do for mine is take o ff the door panel and with some ruff 80grit sandpaper and ruff up the back of the busted plastic all over and first use a hot glue gun to seal the busted/cracks.... then with some fiberglass and resin mixed up apply over the back side...
the hot glue will keep the resin from leaking thru the cracks and soaking into your stock fabric and messing it up and then the resin and fiberglass on the back side will firm it all up solid again.
ive thought it out already i just havent done it yet.... im also thinking about recovering the arm rests with some tweed.... i think its fairly simple to do.... just heat up the melted joints along the back and pull that insert piece out and recover it and simply melt the piece back onto the main panel.
i think the arm rest breaks due to people geting out from the back seat and using it as a brace to get out... my civics only got 78K miles on it when i got it and its busted like this!
Old Sep 15, 2008 | 06:51 PM
Jonathan_ED3's Avatar
On my friends car we took the door panel off, roughed it up really good on both sides with course sandpaper, cleaned it thoroughly, and used fiberglass on both sides.
Make sure to lay it smooth and you wont notice it under the cloth material on the armrest.
Now is a good time to do the CTR style armrest cloth if you want.
Old Sep 15, 2008 | 06:53 PM
EKtypeRhaTcH's Avatar
i have extra door inserts if you wanna buy one. I can sell it to you for cheaper then buying fiber glass haha. Need to get them out of the garage.
Old Sep 15, 2008 | 06:54 PM
I think all EK door panels eventually end up with an elbow hole in them. I think Honda used too thin of plastic, or got the mixture wrong because they are all so brittle.
It's not whether or not you have an elbow hole, it's how soon til you get the elbow hole
Old Sep 15, 2008 | 06:55 PM
Ghetto Civic HX's Avatar
I love to drive
Default Re: (EKtypeRhaTcH)
Man, I must be fat. I broke mine at 30K miles
Old Sep 15, 2008 | 06:56 PM
Jackie-O's Avatar
^are they just stock fabric inserts?
Default Re: (Ghetto Civic HX)
not fat, just big elbowed.
suhteevin
Jan 6, 2009 09:04 PM
Frost7177
Oct 27, 2008 01:31 PM
chiggin
Honda Civic (2006 - 2015)
Aug 28, 2007 11:31 AM
inty2511
Mar 25, 2004 05:27 PM
snake01
Jan 11, 2002 09:06 PM
