cast pistons no oil squirters???
ok i have a gsr block with .50 over pr3 rsmachines pistons i had a machine shop blueprint the block and they said that the skirt on the pistons was hitting the oil squirters but that he tried bending the oil squirter slightly for clearance but that it was then touching the crank i havent got the block back yet to verify this but i know ls's dont have squirters and people build reliable ls/vtecs with cast pistons but i want to be sure my motor will be ok without the squirters
my motor is over 2 years old now. recently re-tuned at prostreet import and still making 'decent' powers. motor doesn't come with oil squirters...still running 'strong' and healthy after over 2 years of daily driving, drag racing and 'non-sanctioned' events.
pm me if you need more info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CerealKiller »</TD></TR><TR><TD CLASS="quote">no need for oil squirters when running aftermarket pistons. all you need is a oil squirter plug set, GE sells them.</TD></TR></TABLE>
yeah but RS machines pistons are cast just like OE.
I think it would be beneficial to keep them if you plan to beat on the car on the track - perhaps try notching the skirt like some have done?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel »</TD></TR><TR><TD CLASS="quote">
oh...
oh...
yea i would do that but the bottom end is already fully balanced and its gunna suck having to take apart the block again and pay to have it notched and rebalanced when there are ls/b20/vtecs that are built right that are still going strong. this will be my dd and im not gunna beat on it all the time the compression is only at 11.5 and the rs machine pistons come with a coating on them i think i will be ok. plus rsmachines pistobs should already come notched like the stock pistons
if i would have known before i would have notched it. they should at east let everyone know about it before hand
Sorry to bump an old thread but this information is very important to me. I was be using LS crank & rods in my GSR Block. but instead I've decided to go with 82mm RSMachine PR3's. Should I be worried about the same thing happening to me?
I also heard of people having problems with the LS crank touching the squirters in a GSR block as well.
so will plugging up the squirters affect anything performance wise?
just from what i have observed: hondas run and live under much more stress with cast pistons than other motors that do not have them. i would not want to be turning 9k with no oil squirters on a cast slug. if you want to avoid oil squirters 4032 forged aluminum would be a better choice in a high heat environment. ring choice is also important. you can fracture a cast ring if you keep it hot long enough. nitraded steel will not fail under the stress of a track day nearly as fast.
Its not really about the squirters anymore because you answered my question on that matter.
more about the rods not liking 8000rpm's. I mean I've never dealt with LS/VTEC type builds so I wouldn't really know. I know that A) I should upgrade the rod bolts & B) possibly get the rods shot peened
idk.. I don't want to spin a bearing or something..
mitchell_2kSiR
Jul 29, 2008 08:28 AM
sweet
Apr 24, 2003 10:29 AM
