Anyone installed Ingalls front and rear camber kit?
Im pretty sure after the installation it dropped my, already lowered ride height, significantly.
Now just cruising around town, slowly mind you, im getting mad tire rub. Just curious if anyone else ran into the same problem. Thanks
no tire rub. i got the kit that adjusts something like plus or minus 1.5? it didn't fit into the controll arms so i had to grind it down. i have around 2 degrees of negative cameber but NO TIRE RUB
Did you get an alignment? It sounds like you have the kit installed and the the tire is at full positive and it is rubbing because of that
I did the install myself and finished it up friday evening. I did an eyeball adjustment so that it wasn't way to positive or negative.
Im waiting till monday to get an alignment, seeing as the alignment guys are closed on weekends.
It sounds as if its rubbing only on the rear
Tire size is the stock size: 185/60r on 14 in rims.
As for rolling the fenders, how do I go about doing that? Easy DIY? Or would I have to have an auto body shop do it?
i've done it before on a hachi using a large metal pipe/baseball bat... here's a good movie on how to do it (note- it's in japanese i think, so you have to watch it for the how to)
http://www.youtube.com/watch?v=DDTK9IjKIYU
Visually informative.
Listening was comedic.
I'll give it a shot and see what happens, after I have the car aligned and the camber adjusted.
mtrivera
Oct 9, 2008 04:19 PM
