Quick responds pls, Tire size.etc
Got my honda accord 01 coupe back from paint shop; titanium silver metallic.
my rims size are 18x8.5 front and 18x9.5 rear
what tire size should i go. i think offset is 42.
what tire size? pls and yes i do got a camber kit for the rear and my front and rear fenders will be rolled.
He knows where you live!
Re: Quick responds pls, Tire size.etc
1) You shouldn't bump more than once a day
2) I've got a feeling you're going to rub quite a bit, so I hope you rolled your fenders - why you didn't do this BEFORE the vehicle was painted I will never know.
3) You don't mention if you're lowered either, I assume this is why you bought the camber kit.
I probably would have test fit everything prior to purchasing and see what other 6th gen Accords are running wheel/tire wise. I think you may have a difficult time driving with those wheels after adding tires.
This will tell you what tire will be equivalent to your OEM size and/or would tell you how far off your speedometer will be.
http://www.miata.net/garage/tirecalc.html
kingofnothing
12
09-15-2008 10:01 AM
