Hondata Boost Control Solenoid Question? Just Hooked It Up
Old Sep 13, 2008 | 06:11 AM
SDHonda153's Avatar
Default Hondata Boost Control Solenoid Question? Just Hooked It Up
Question... I just hooked up the Hondata boost solenoid in my 94 Ex yesterday. Running a Tial external wastegate I've got the top side hooked to COM and the boost/vacuum source hooked to NC of the solenoid, leaving the normally open to vent. (Wanted it hooked this way just in case of a failure I'd still be running off the WG spring) And the bottom side hooked to the boost/vacuum source like normal. Yet now when I start the car, there is a decently strong vacuum coming from my NO side of the valve which would mean its coming from the top side of my WG. Is this commonly what happens and that's why they usually put the muffler there? Or I was thinking maybe I'm leaking air through my diaphragm in the WG. Wanted to get a second opinion before I went tearing into the wastegate. Thanks
Old Sep 13, 2008 | 06:39 AM
Turbo-charged's Avatar
Default Re: Hondata Boost Control Solenoid Question? Just Hooked It Up (SDHonda153)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SDHonda153 &raquo;</TD></TR><TR><TD CLASS="quote">Question... I just hooked up the Hondata boost solenoid in my 94 Ex yesterday. Running a Tial external wastegate I've got the top side hooked to COM and the boost/vacuum source hooked to NC of the solenoid, leaving the normally open to vent. (Wanted it hooked this way just in case of a failure I'd still be running off the WG spring) And the bottom side hooked to the boost/vacuum source like normal. Yet now when I start the car, there is a decently strong vacuum coming from my NO side of the valve which would mean its coming from the top side of my WG. Is this commonly what happens and that's why they usually put the muffler there? Or I was thinking maybe I'm leaking air through my diaphragm in the WG. Wanted to get a second opinion before I went tearing into the wastegate. Thanks </TD></TR></TABLE>
should not have vacuum on the side port of the gate. if there isnt a port on the compressor housing for the pressure source, we drill and tap and make one.
Old Sep 13, 2008 | 07:48 AM
SDHonda153's Avatar
Default Re: Hondata Boost Control Solenoid Question? Just Hooked It Up (Turbo-charged)
I have it hooked into a vacuum block now, you recomend I move it to the compressor housing? Maybe a dumb question, but wouldn't there be vacuum there as well when not under boost?
thegatekeeper14
Jul 6, 2010 12:53 PM
eaddagwan
Engine Management and Tuning
13
Aug 20, 2009 07:54 AM
spoon95eg
Jan 15, 2006 05:15 PM
boosted_duece
Nov 16, 2005 03:35 PM
DXK Eg
Jan 13, 2005 02:19 PM
