squeek in clutch
Old Jul 25, 2002 | 11:19 AM
turismo949's Avatar
Default squeek in clutch
everytime i push/release the clutch on my 5th gen Lude it squeeks, how do i lubricate it, it sounds like its coming from behind the wall - not where the pedal is... is my clutch just bad, should i just replace it? or can this be temporarily fixed, im trying to sell it...thanks
Old Jul 25, 2002 | 04:50 PM
turismo949's Avatar
Default Re: squeek in clutch (turismo949)
^bump^
Old Jul 25, 2002 | 06:07 PM
StyleTEG's Avatar
Sounds like your master/slave cylinder are going bad.
Old Jul 25, 2002 | 07:59 PM
976's Avatar
976
New User
Default Re: squeek in clutch (StyleTEG)
Check for leaks, have someone press clutch while you listen. Most likey your slave.
Pressure release bearing not anti-seized - last resort!
Old Jul 25, 2002 | 08:15 PM
turismo949's Avatar
Default Re: squeek in clutch (w00t!)
ummm...it did the squeeking/creeking before I just replaced the master cyclinder, is the new one bad???
Old Jul 28, 2002 | 12:27 PM
turismo949's Avatar
^push^
Old Feb 24, 2004 | 11:04 PM
manekDC2.'s Avatar
mine does the same thing.. just got a new slave and master clutch cyl. and still have a squeek with my ACT XTSS setup??
94_Teggy
May 11, 2009 10:58 AM
b16a4
Nov 18, 2006 11:04 AM
s1ngle
13
Sep 21, 2005 12:01 PM
SikofFalln
Apr 25, 2003 02:49 PM
5 Liter Eater
Aug 13, 2001 01:52 PM
