Cleaning 5 year old oil
Old Sep 11, 2008 | 11:23 AM
spikehead221's Avatar
From: Staring down the barrell of my 12 ga. Texas, USA
Default Cleaning 5 year old oil
right, so i am rebuilding a 91 sedan that has been sitting for 5 years now. it has been sitting around because the timing belt broke, and a couple of valves are bent. well my question is what should i use to get the "frosting" that is the oil off of the head, rocker arm assembly and so forth.
in advance, thanks
Old Sep 11, 2008 | 11:27 AM
DynastyRacer22's Avatar
Default Re: Cleaning 5 year old oil (spikehead221)
try aircraft remover it might work but i could be wrong someone correct me?
Old Sep 11, 2008 | 11:44 AM
7PSI CRX's Avatar
Default Re: Cleaning 5 year old oil (DynastyRacer22)
You need:
Citrus Degreaser
JRZ88DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DynastyRacer22 &raquo;</TD></TR><TR><TD CLASS="quote">try aircraft remover it might work but i could be wrong someone correct me? </TD></TR></TABLE>
Aircraft might work
Hit it with some Seafoam or possibly Simple Green
Old Sep 11, 2008 | 11:45 AM
rbwdriven's Avatar
I'd say either air craft stripper, orange cleaner or carb cleaner.
Just be very careful when you put it all back together that there is no residue left over.
you could also try the oil treatment that you run in an engine for about 5 minutes to clean stuff out. I think it is basically paint thinner.
Old Sep 11, 2008 | 11:56 AM
90_EX_Civic's Avatar
Default Re: (rbwdriven)
soak it in some automatic transmission fluid, then use a soft plastic brush to scrub it. the trans fluid has some degergents in it and is basically what quick oil change shops use for motor flush(just not labeled trans fluid).
if that sounds to extreme, try wd40. it is basically a degreaser and it won't really hurt anything. just make sure you re lube before install.
Old Sep 11, 2008 | 12:29 PM
BAZ's Avatar
BAZ
Default Re: (90_EX_Civic)
Brake cleaner and a brush.
Old Sep 11, 2008 | 01:56 PM
johnnyonth3spot's Avatar
Default Re: (BAZ)
lock it in a vice and pressure wash it
Old Sep 11, 2008 | 03:22 PM
gringo7718's Avatar
Default Re: (johnnyonth3spot)
Let it soak in a bucket of degreaser or whatever solvent you have for a few days. Then have at it with as wire brush.
Old Sep 11, 2008 | 04:14 PM
Crx Jimmy's Avatar
Default Re: (gringo7718)
let it sit in a bucket of diesel for a couple days then drop it in a bucket of gas and go at it with a tooth brush
Old Sep 11, 2008 | 05:47 PM
GLI's Avatar
GLI
Default Re: (Crx Jimmy)
Go to pick/pull swap it out....
Old Sep 11, 2008 | 06:38 PM
tico's Avatar
laquer thinner or the politicaly correct term due to VOC's would be spay gun cleaner.. aircraft stripper is way to strong could also act as an acid on the cam valves and such. start small work ur way up
Old Sep 11, 2008 | 07:02 PM
Deetz's Avatar
Crazy Honda Guy
Don't waste your time with that head, bent vales, don't waste your time!
The local junk yard will have a good one for like $50, maybe less
Old Sep 11, 2008 | 09:58 PM
Default Re: (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">Don't waste your time with that head, bent vales, don't waste your time!
The local junk yard will have a good one for like $50, maybe less </TD></TR></TABLE>
we dont know if there is bent valves or not. we are gonna get it checked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rbwdriven &raquo;</TD></TR><TR><TD CLASS="quote">
you could also try the oil treatment that you run in an engine for about 5 minutes to clean stuff out. I think it is basically paint thinner.</TD></TR></TABLE>
car doesnt run, and the head is off (see pics)
g2b2
May 11, 2007 12:56 PM
Kwayzie
16
Mar 20, 2007 04:28 PM
jetlude
Aug 14, 2004 07:57 PM
Kid1320
10
Apr 16, 2004 09:55 PM
jerky
Jun 23, 2003 11:00 AM
