noob question
i read a lot of sites on turbos but never says anything about a tunning the ecu. i have a 95 eclipse turbo and i was wondering. if i put the turbo on and the injectors will i need to get the ecu tuned? or is it possible to run it as it at whatever the stock boost for the eclipse are?
You will need to get tuned if you are putting on larger injectors. Many times you can get away w/o tuning on a 4G63 if you are running stock boost, but since you are putting in injectors, I'd get it tuned as well. Dpending on your setup, you might be able to just get away with a piggyback.
Mephistopheles
Feb 15, 2021 05:17 PM
