Anybody Running Boost on a D16Z6 with 76.6mm? GE sleeved! Need advise soon!
Old Sep 10, 2008 | 08:44 PM
Boostfed86's Avatar
Default Anybody Running Boost on a D16Z6 with 76.6mm? GE sleeved! Need advise soon!
Just a quick question for a possible future build. Recently started my D16Z6 build. Will start as a built bottum end on my newly purchased GT3076R until i get my oversized valves, springs, retainers and etc in a new head. I have recently run across a local guy with a Golden Eagle sleeved Z6. My concern with this block is that its been bored previously to 76.5mm. I plan to drive this motor on a regular basis and ofcourse see a lot of track time. Is there anyone here on a bore this big thats running a good amount of boost(ie-25+psi)? Anybody have any opinions on this? Any info is good info!
Old Sep 11, 2008 | 04:33 AM
Boostfed86's Avatar
Default Re: Anybody Running Boost on a D16Z6 with 76.6mm? GE sleeved! Need advise soon! (Boostfed86)
anybody out there?
Old Sep 11, 2008 | 08:22 PM
Boostfed86's Avatar
help me please!
Old Sep 11, 2008 | 09:32 PM
BiggieBert's Avatar
Loved
Community Favorite
thats pretty big, I'm boostin my z6 75.5 stock sleeve at 15psi wit t3/t4. i'd be inclined to say you would be ok, but how much extra are custom pistons? do u already have a block, if so I would just sleeve it if ur wantin sleeves then bore to ur likening.
Old Sep 12, 2008 | 09:09 AM
Boostfed86's Avatar
Default Re: (BiggieBert)
I'm hearing good things so far. Anyone have any more input?
Old Sep 12, 2008 | 09:17 AM
SovXietday's Avatar
Default Re: (Boostfed86)
If it's sleeved the only problem you're going to run into is getting a headgasket that's big enough. Other than that, you're fine.
Old Sep 12, 2008 | 10:42 AM
Boostfed86's Avatar
Default Re: (SovXietday)
Does anyone make one that big?
Old Sep 12, 2008 | 10:47 AM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed86 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone make one that big? </TD></TR></TABLE>
Yes, but it would be one off, any of the aftermarket headgasket makers should be able to get you one.
You will also need a custom sized set of pistons like mentioned before, which again just about anyone will do but you're going to have to spend a little extra.
There's a few guys running around with 78mm bores, so it's all possible. If you can track them down I'm sure they could answer the one off questions a little better.
Elitesky
12
Aug 5, 2010 10:48 AM
Mr.Kalinchuk
Apr 11, 2010 05:15 PM
dhn
Jul 23, 2007 02:50 PM
allmotrjdm
Jan 16, 2004 08:19 AM
pbomers
Jun 8, 2002 12:27 AM
