Turbo Related Questions
Old Sep 10, 2008 | 05:10 PM
CTR_B's Avatar
Default Turbo Related Questions
So I have some question about a B-series turbo (B16-T3/T04E)
1. After engines warmed up the oil light fickers or is on under 1.5 Rpms
( -10 Return belive -4 feed ) What or why does this accour?
2. Turbo whine, Simular to how a semi or dumb truck would sound but all the time even when steady on the gas.
(T3/T04e with 3in down pipe that goes straight down from turbo and stops at oil pan)
3. Ever since I installed the turbo (hmt kit) I Have herd this whine sound coming from the Itake cam erea of the head next to the cam gear. I at first thought this might be related to the oil light but it does it even when the light isnt on. Sounds simular to a S.c?
Any ideas?
Old Sep 10, 2008 | 07:57 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Turbo Related Questions (CTR_B)
how much oil pressure? did you put a manual gauge on it?
Old Sep 10, 2008 | 08:20 PM
TheShodan's Avatar
Moderator
-4AN is large for a feed, and make sure that the return line isn't kinked. As for the rest, whoa... there's a lot more going on than you may be telling us.. more information, please.
Old Sep 11, 2008 | 04:05 AM
CTR_B's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">-4AN is large for a feed, and make sure that the return line isn't kinked. As for the rest, whoa... there's a lot more going on than you may be telling us.. more information, please.</TD></TR></TABLE>
I will be more then willing to give you all the information you want, Just let me know what iformation you need
QUOTE=boostedcivicsir]how much oil pressure? did you put a manual gauge on it?[/QUOTE]
I have a manual gauge, Just havent installed it yet. I have been so busy at the shop I just havent had any time. I will install it soon and post the numbers
Modified by CTR_B at 7:56 PM 9/12/2008
Old Sep 12, 2008 | 06:56 PM
CTR_B's Avatar
Default Re: (CTR_B)
Any help?
Old Sep 15, 2008 | 08:29 AM
TheShodan's Avatar
Moderator
Information like:
-Was the turbo new or used when you bought it?
-The downpipe ends at the Oil pan? Or is this the dumptube coming from the wastegate?
-Is there any smoke coming from the exhaust system?
-Is there any oil from the turbocharger?
-Was it recently abused? used heavily?
-What is your oil pressure AT THE LINE?
Old Sep 15, 2008 | 10:44 AM
CTR_B's Avatar
Information like:
-Was the turbo new or used when you bought it? -USED
-The downpipe ends at the Oil pan? Or is this the dumptube coming from the wastegate? THE DOWN PIPE IT SELF ENDS AT THE OIL PAN
-Is there any smoke coming from the exhaust system? YES
-Is there any oil from the turbocharger? YES INBETWEEN THE HOT AND COLD PARTS OF THE TURBO IT LEAKS
-Was it recently abused? used heavily? ITS BEEN DRIVEN ON
-What is your oil pressure AT THE LINE? DONT KNOW
Old Sep 15, 2008 | 07:41 PM
TheShodan's Avatar
Moderator
These are some serious problems here. You've used too big of a line, to where it is possible you've destroyed the seals of the turbocharger. I also would change that downpipe location away from that pan to not heat up the oil any more. I'd make sure that no 90 degree angles on the return of your turbocharger, you may experience the same thing after a rebuild. Pictures could really help.
dturbo
Apr 5, 2005 03:44 PM
B18badboy
Apr 27, 2004 09:01 PM
Ntrpriz
Jun 29, 2003 08:10 PM
Wide Open Throttle
Jun 28, 2003 10:45 AM
T4sol
Aug 5, 2002 04:58 PM
