Camshaft holder tool
Old Sep 10, 2008 | 04:29 PM
vinuneuro's Avatar
Default Camshaft holder tool
Do any of you use camshaft holder tools that you can recommend? It's just such a pita to keep the cams from moving when installing the timing belt. The small holes in the cam plate/cams are good for torquing the cam bolts but they do allow a few mm of play.
Old Sep 10, 2008 | 04:41 PM
Garrett's Avatar
I want one too
Old Sep 10, 2008 | 05:04 PM
SP GARAGE's Avatar
Default Re: (Garrett)
i have a matco one for sale brand new if anyone is intrested
Old Sep 10, 2008 | 05:06 PM
vinuneuro's Avatar
Default Re: (FLATBUSH PROJECTS)
Is it this one? Did it work?
Old Sep 10, 2008 | 05:39 PM
SP GARAGE's Avatar
Default Re: (vinuneuro)
naw its not that one.... ive never used it. i always just have one of my buddies of the gears with a wrench
Old Sep 10, 2008 | 05:51 PM
ruffrhyder's Avatar
http://cgi.ebay.com/ebaymotors...33141
Old Sep 10, 2008 | 06:02 PM
projectTeG's Avatar
hell, i havent ever needed one. my cams stay still on my head.
Old Sep 10, 2008 | 06:44 PM
IN VTEC's Avatar
Default Re: (projectTeG)
I don't use them either.
Old Sep 10, 2008 | 06:47 PM
vinuneuro's Avatar
Default Re: (IN VTEC)
I don't know what the problem is. Others I've talked to say the cams don't move when installing the belt either. What ends up happening is that the intake cams moves a tooth or two counterclockwise and the exhaust cam does the same thing, but clockwise.
Old Sep 10, 2008 | 06:58 PM
96Spec Ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">Is it this one? Did it work?
I've seen that one on the snap on truck. I think a company OTC makes it. Kind of iffy if you ask me.
Old Sep 10, 2008 | 07:56 PM
PirateMcFred's Avatar
Never needed it but use the method I suggested.
Where's your build thread anyway?
Old Sep 10, 2008 | 08:58 PM
AllMotorRandy's Avatar
Default Re: Camshaft holder tool (vinuneuro)
Here is a tool that I use for b-series vtec motors... too bad that don't make one for H22's because it works great! Best tool i've used so far.
Old Sep 11, 2008 | 10:53 AM
vinuneuro's Avatar
Default Re: (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">Never needed it but use the method I suggested. </TD></TR></TABLE>
Going to the hardware store soon. Will post results.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Where's your build thread anyway?</TD></TR></TABLE>
Excuse me?
Old Sep 11, 2008 | 04:13 PM
7rrivera7's Avatar
Default Re: (ruffrhyder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruffrhyder &raquo;</TD></TR><TR><TD CLASS="quote">http://cgi.ebay.com/ebaymotors...33141</TD></TR></TABLE>
Please explain how these work - I'm too tired to figure it out
Old Sep 11, 2008 | 04:15 PM
vinuneuro's Avatar
Default Re: (7rrivera7)
Blake/98vtec tried that tool and returned it because it didn't work well.
Old Sep 11, 2008 | 04:20 PM
Lubo_25's Avatar
heavy duty zip ties work for me
Old Sep 12, 2008 | 07:30 AM
98vtec's Avatar
moderator emeritus
Default Re: Camshaft holder tool (Lubo_25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote">heavy duty zip ties work for me </TD></TR></TABLE>
thats what i told him
Old Sep 12, 2008 | 05:08 PM
frostyrb's Avatar
Default Re: Camshaft holder tool (98vtec)
why do you need a tool? just move the cam back with a wrench on the cam gear bolt. put the belt on the pulley. then put the wrench on the other gear bolt up till the marks match up on both gears. slide the belt on & set the tensioner. then take the crank around 2 times & check the tension on the belt. this is not rocket science, & NO tool is needed.
Old Sep 12, 2008 | 05:14 PM
Lubo_25's Avatar
cheers to zip ties
Old Sep 15, 2008 | 09:04 AM
How'd it end up?
PURPLERANGER
Sep 9, 2014 12:19 AM
vttitan18
Jun 5, 2008 05:22 AM
94b16teg
Aug 11, 2006 09:11 AM
B18C
Jul 30, 2003 03:30 PM
EG6[B16A1]
Apr 27, 2003 08:19 AM
