how to time cams????
hi, I've looked everywhere for resource, still I'm not clear on how to time cams after installing them, please leave detailed info or links that relate to this matter...
Cam Timing info for a B16A1 or B17A
also I have a question I need info on the B16A1 cams and B17A cams, I was wondering is there any difference on the two cams, or are the head of a B17 different from a B16A1??
thanks, Fishman
thanks, Fishman
Re: how to time cams???? (F15HMAN[BYM])
Simply set the #1 Piston at Top Dead Center. then line the marks on the cam gears up with the arrows pointing up. The marks should be even with the top of the head. Then slide the timing belt on, correct the tension, and you are ready to go. It's simple.
lifeschase
Honda CR-V & Element
05-28-2016 09:03 AM
