Failed Smog! Help
Old Sep 10, 2008 | 01:21 PM
7mile's Avatar
Default Failed Smog! Help
HC was 130 allowed is 100... ignition problem? suggestions?
i remember i had to retard the timing last time i got it smogged... thanks
Old Sep 10, 2008 | 01:29 PM
baller status's Avatar
Default Re: Failed Smog! Help (7mile)
HC is partially burned fuel usually indicative of a poor ignition system or retarded timing. On a Honda sometimes it can be caused by your valves being out of adjustment.
Old Oct 4, 2008 | 10:05 PM
typeRmike055's Avatar
just heat up the cat before u smog it that should do the trick
Old Oct 5, 2008 | 07:09 AM
honda.lioness's Avatar
Elevated hydrocarbon (HC) emissions usually indicate ignition misfire due to fouled spark plugs or a bad plug. But high HC emissions can also be caused by burned exhaust valves (check compression), lean misfire (check for vacuum leaks, low fuel pressure or dirty injectors), or rich fuel conditions (fuel saturated carburetor floats, excessive fuel pressure, leaky injectors or a dead O2 sensor). -- Larry Carley, Automotive writer
See also:
http://www.20v.org/emissions.htm
http://www.aircare.ca/index.ph...y.php Go to HC definition.
Old Oct 8, 2008 | 09:47 AM
FTP racing's Avatar
Default Re: Failed Smog! Help (honda.lioness)
IF SUPER HEATING YOUR CAT DON'T WORK YOU CAN CHECK YOUR PLUGS AIR FILTER CHECK YOUR OIL FOR FUEL SATURATION OR YOU CAN JUST DROP A NEW CAT AND CALL IT A DAY...YOU CAN ONLY RETARD + OR - 2 DEGREES MAX ON HONDAS...UNLESS THE TECH DON'T CHECK THEN YOUR IN THE CLEAR...
MCAZ92
18
Nov 19, 2017 03:13 PM
brdude
18
Jun 29, 2013 06:50 AM
BlackDB8
13
Oct 5, 2011 11:31 AM
EFb18b
Jul 20, 2006 04:48 PM
chill00
May 25, 2004 07:36 AM
