HC fail in car inspection.......help
Old 05-25-2004, 06:50 AM
chill00's Avatar
Default HC fail in car inspection.......help
it shows exhaust emission test results: fail
Gas Reading Standard
HC(ppm) 228 220
CO (%) 0.18 1.20
What can I do to fix it? Thanks a lot.
Old 05-25-2004, 07:24 AM
suspendedHatch's Avatar
Default Re: HC fail in car inspection.......help (chill00)
HC is fuel. You're not burning the fuel. Did you bump your fuel pressure or use larger injectors or something? If not then maybe it's your ignition system.
Old 05-25-2004, 07:36 AM
SOHFAST94's Avatar
Default Re: HC fail in car inspection.......help (shaundrake)
You could try advancing the timing some and that may compensate depending on where the timing is now and your ingition/ecu system configuration.
GoLowDrew
04-06-2011 04:09 PM
7mile
10-08-2008 09:47 AM
TURBODEEZ
10-11-2005 02:38 PM
Quick Reply: HC fail in car inspection.......help
