Carbon Fiber Hood?
Old Sep 10, 2008 | 07:47 AM
Civic Hybrid's Avatar
Default Carbon Fiber Hood?
My CF hood is staring to really look a little shady. Startin to fade and get ruff to the touch. How would I go about saving it? I was thinkin about asking a paint/ body shop if they can just respray it with clear coat. Will that work?? Any other suggestions will be appreciated.
Old Sep 10, 2008 | 07:50 AM
yessewey's Avatar
Default Re: Carbon Fiber Hood? (Civic Hybrid)
yeah i've seen a couple ppl do that and it turns out like new. or u could use that nu finish car wax i think it is and it works too, but only until it gets exposed to water then your back at where you started.
Old Sep 10, 2008 | 09:19 AM
alphalanos's Avatar
For best results youll need to sand off the clearcoat and re clear it. If they just spray over the existing clear coat it wont look as good.
Old Sep 10, 2008 | 10:12 AM
Mingo's Avatar
Default Re: Carbon Fiber Hood? (alphalanos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphalanos &raquo;</TD></TR><TR><TD CLASS="quote">For best results youll need to sand off the clearcoat and re clear it. If they just spray over the existing clear coat it wont look as good.</TD></TR></TABLE>
That's what i did to my CF hood and it'll look like new again
Old Sep 10, 2008 | 03:56 PM
So sand it down and **** first, then go get it resprayed? Any tips on the sanding down part?? procedure? thks.
Old Sep 10, 2008 | 05:55 PM
dannym88's Avatar
Default Re: (Civic Hybrid)
yeah dude i have a vis carbon hood on mine and i just resprayed it with a ppg clear all the **** i needed cost me like 40bux i forget what it was a friend helped me out but we just sanded the old coat with like 800grit sand paper and used a water hose just to keep everything wet so just wet sand the **** out of it for a while like it took me a couple of hours of sanding cuz my **** was so messed up but yeah it worked
Old Sep 10, 2008 | 06:26 PM
soclean1k_JDM's Avatar
Default Re: (dannym88)
any pictures?
have the same issue
Old Sep 10, 2008 | 06:35 PM
dannym88's Avatar
Default Re: (soclean1k_JDM)
yeah i never took the before pic but check out my thread on my hatch and you should see it kinda its clean from what it was before cant really see it too well tho but it's there https://honda-tech.com/zerothread?id=2384763
Old Sep 10, 2008 | 09:52 PM
94_Civic_Hatch's Avatar
Regular clear or gel coat?
Will it still look good if you jus reclear it with regular clear?
Old Sep 11, 2008 | 08:46 AM
dannym88's Avatar
Default Re: (94_Civic_Hatch)
i dont really know go to your local paint dealer and just tell them your issue they should help you out that's what i did and just find somebody with a paint gun or take it to a shop if you really have to but that's my best advice i dont really know what i bought all i know was it was like a reducer or some crap and the other was the actual clear but i got ppg **** cuz that's like oem quality i didnt even have to do more than one coat and no wet sanding after the first cuz it came out so good
VTEC_Du_Ma_Mai
Oct 31, 2007 09:57 PM
jaime83
Paint and Body
Sep 6, 2007 04:29 AM
ProjectCD5
Sep 24, 2006 08:22 PM
LODOSS
Nov 24, 2003 10:21 AM
J T*
Dec 6, 2002 06:17 PM
