LS VTEC SUGGESTIONS FOR 200 HP
Old Sep 9, 2008 | 06:18 PM
mande456's Avatar
Default LS VTEC SUGGESTIONS FOR 200 HP
HOW YA DOIN HONDA TECH PEOPLE IM TRYIN TO BUILD A RELIABLE LS VTEC SETUP WIT TYPE R INTERNALS THAT WILL GET ME AT AROUND 190 - 200HP...I WAS HOPIN IF YA CUD GIVE ME SUGGESTIONS ON GETTIN THERE
THIS IS MY SETUP:
GSR HEAD
PORT AND POLISHED
3 - ANGLE VALVE JOB
CTR SPRINGS, VALVES AND RETAINERS
CTR INTAKE CAM
GSR EXHAUST CAM
AEM CAM GEARS
SKUNK2 INTAKE MANIFOLD & THROTTLE BODY
RC 440CC INJECTORS
AEM V2 COLD AIR INTAKE
HYTEC REPLICA HEADERS
NGK SPARKPLUG WIRES
GOLDEN EAGLE LS V KIT 81 MM
AEM FUEL RAIL
AEM FUEL REGULATOR
B18B1 BLOCK
CTR PISTONS
OEM BEARINGS
CTR CRANK PULLEY
CTR WATER PUMP
CTR OIL PUMP
ARP RODS AND BOLTS
2.5" STRAIGHT PIPPIN
APEXI WORLD SPORT 2 EXHUAST
TYPE R TRANNY
ACT 6 PUCK CLUTCH
ACT EXTREMME PRESSURE PLATE
ANY SUGGESTIONS ON GETTING TO 200HP????
Modified by mande456 at 7:26 PM 9/9/2008
Modified by mande456 at 7:51 AM 9/10/2008
Old Sep 9, 2008 | 07:06 PM
mande456's Avatar
Default Re: LS VTEC SUGGESTIONS FOR 200 HP (mande456)
ANY SUGGESTIONS WILL BE GREATLY APPRECIATED
Old Sep 9, 2008 | 07:36 PM
92integraVTECgsr's Avatar
well I'll let you know in a week or 2.
My LS/VTEC put down 187whp and I just ordered a Hytech Replica regular tube header and I will be order a BPi Velocity stack as well. My new goal is to break the 200whp mark.
With you list of parts and build I would assume around you will be pretty close. I'm not sure if I would use CTR pistons if you plan on daily driving the car.
Here is a link to my build.
https://honda-tech.com/zero...age=1
Old Sep 9, 2008 | 08:59 PM
steveteggy92's Avatar
Who did your head work?
Old Sep 9, 2008 | 09:01 PM
mande456's Avatar
Default Re: LS VTEC SUGGESTIONS FOR 200 HP (steveteggy92)
MY BOY WORKS AT HIS OWN MACHINE SHOP
Old Sep 9, 2008 | 09:58 PM
Dat1BVtecN's Avatar
Yea this is another noob thread about ls/vtec. Ill answer your question and i got plenty experience with ls/vtec.
YES, just get a decent tune. YESYES
Wat the heck is GOLDEN EAGLE LS V KIT 84 MM? is it not stock bore or something? BLa, waste of time. but YES
Old Sep 9, 2008 | 10:11 PM
riceball777's Avatar
the only thing holding you back in that set up are the cams.
get some real cams like skunk2 pro 1's or any other cams that are in that size range.
your not going to break 200whp with stock gsr cams
Old Sep 9, 2008 | 10:17 PM
mande456's Avatar
Default Re: LS VTEC SUGGESTIONS FOR 200 HP (riceball777)
THNX FOR THE HELP...TRYIN TA STAY OEM WITH THE INTERNALS..IM REALLY FOCUSED ON RELIABILITY AND ALSO BREAKIN 200HP
Old Sep 9, 2008 | 11:06 PM
I AM WEASEL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mande456 &raquo;</TD></TR><TR><TD CLASS="quote">ANY SUGGESTIONS WILL BE GREATLY APPRECIATED</TD></TR></TABLE>
My suggestion TAKE THE CAPS LOCK OFF!
Old Sep 10, 2008 | 05:40 AM
98vtec's Avatar
moderator emeritus
Default Re: LS VTEC SUGGESTIONS FOR 200 HP (-DC4-)
What's the obsession with 200whp? You know you can make 200 and still get beat by 180whp right?
Old Sep 10, 2008 | 06:36 AM
Phil M's Avatar
Default Re: LS VTEC SUGGESTIONS FOR 200 HP (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">What's the obsession with 200whp? You know you can make 200 and still get beat by 180whp right?</TD></TR></TABLE>
That sentence was too dense with info for him to understand. Go slower.
Old Sep 10, 2008 | 06:50 AM
00b20vtecoupe's Avatar
Default Re: LS VTEC SUGGESTIONS FOR 200 HP (Phil M)
get some real cams those r gonna kill you.. and wats up with the 84mm vtec kit??? u kno thats for a b20 block right?? your ls is 81mm unless you bored it or sleeved it. i belive the 84mm is referring to the headgasket it came with???
Old Sep 10, 2008 | 06:51 AM
mande456's Avatar
Default Re: LS VTEC SUGGESTIONS FOR 200 HP (00b20vtecoupe)
thnx for the info on the kit..i messed up
Old Sep 10, 2008 | 08:13 AM
omniman's Avatar
And dont buy "replica, counterfeit or knock off parts"
can i get a refund this movie sucks.
Old Sep 10, 2008 | 09:13 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: LS VTEC SUGGESTIONS FOR 200 HP (omniman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omniman &raquo;</TD></TR><TR><TD CLASS="quote"> And dont buy "replica, counterfeit or knock off parts"
Or anything by Omnipower for that matter...
Old Sep 10, 2008 | 09:26 AM
Default Re: LS VTEC SUGGESTIONS FOR 200 HP (2LEM1)
wats wrong with omnipower?
Old Sep 10, 2008 | 09:45 AM
98vtec's Avatar
moderator emeritus
Blah
ej1b18b1
31
Oct 8, 2009 12:14 PM
mr nut
Nov 13, 2006 06:27 AM
racer034life
19
Oct 2, 2005 10:30 AM
awdriscol4
Dec 30, 2004 11:16 PM
hondaguyef
10
May 22, 2004 11:19 AM
