ATF in tranny before start?
Old Sep 9, 2008 | 09:41 AM
astralshadow's Avatar
Default ATF in tranny before start?
I recently bolted a flexplate, torque converter, and mounted an auto tranny on a previously manual engine. I did not put ATF fluid in the tranny yet and started the motor. I heard a sound like the flywheel was spinning freely once it started and it shot up to 3k rpms before i shut the motor off. Is it possible I didn't align the tranny correctly? or is fluid required on a newly swapped torque converter
Modified by astralshadow at 2:08 PM 9/9/2008
Old Sep 9, 2008 | 03:59 PM
Default Re: ATF in tranny before start? (astralshadow)
no input on this one?
Old Sep 10, 2008 | 04:42 AM
slaminsam's Avatar
I was always told to put a few quarts in the converter before install and start up.. I forgot to fill one up in a stall converter for a mustang one time and the thing would never hit the stall rpm. It was always a few hundred rpm shy.
Old Sep 10, 2008 | 12:01 PM
yeah that sounds a bit right, i was under the impression that the torque converter is only responsible for keeping the engine from stalling once it's started. The transmission is probably unaligned but i don't know how the hell its bolted on if the teeth aren't lining up
Old Sep 10, 2008 | 02:44 PM
_BEN_'s Avatar
The few times that I have installed an auto tranny I pre-filled the converter and made sure that the fluid level on the dipstick was good before starting the engine.
After starting it and letting it idle for a second or two. I would shift it through all of the gears a few times then I would recheck the fluid.
Then I would take it for a test drive and recheck the fluid when I got home.
I would be concerned about roasting the clutch packs or the converter if the engine was started with no fluid in the tranny.
I don't see how anything could be slipping if you did the method I mentioned above and installed the transmission in the correct order.
-Flexplate to crank
-Slide the converter into the tranny
-Attach the tranny to the block
-bolt the converter to the flex plate.
Sometimes it can be troublesome to get the heavy converter to slide into the tranny but I don't see how anyone could get the tranny to bolt up to the engine without the converter all of the way into the tranny. Unless you had a converter from the wrong car or something.
elliascool
Feb 10, 2011 10:19 PM
turboedsupe
Jul 10, 2010 10:23 PM
ea_hatch
Oct 22, 2005 01:09 PM
civicmon
Feb 17, 2004 01:44 PM
uNbrokeN
Jan 16, 2004 12:32 PM
