Transmission & Drivetrain Gearboxes, Differentials, Clutches
would I be able to swap my automatic transmission to a manual?
Old Sep 9, 2008 | 09:09 AM
unxpected323's Avatar
Default would I be able to swap my automatic transmission to a manual?
I have an 03 civic ex model v-tech engine. just wondering if I would be able to swap my automatic transmission to a manual? if so, what kind of transmission would be a good swap? and will it be worth it? thanks for the help!
Old Sep 9, 2008 | 11:54 AM
kalm_traveler's Avatar
Default Re: would I be able to swap my automatic transmission to a manual? (unxpected323)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unxpected323 &raquo;</TD></TR><TR><TD CLASS="quote">I have an 03 civic ex model <U>v-tech </U>engine. just wondering if I would be able to swap my automatic transmission to a manual? if so, what kind of transmission would be a good swap? and will it be worth it? thanks for the help!</TD></TR></TABLE>
There is no hyphen, and no H in VTEC.
With the correct parts, any car can be converted to manual trans from automatic. You'd need pedal assembly, shifter assembly, clutch master cylinder, fluid line, slave cylinder, trans mount hardware in addition to the transmission, flywheel and clutch assembly at the very least.
Some cars will require different axles as well.
Old Sep 9, 2008 | 03:02 PM
H22Honda98's Avatar
Default Re: would I be able to swap my automatic transmission to a manual? (kalm_traveler)
you are better off just buying a car with a 5speed already installed IMO. mine was way more of a hassle than it was worth.
Old Sep 13, 2008 | 11:11 AM
ef_88_hatch's Avatar
also to add to the list that Kalm_traveler posted you will ether need a new manual transmission ECU or have your converted over.
Bobby Rice
Honda Civic (2001 - 2005)
Sep 10, 2010 02:41 PM
adamvogt28
Oct 5, 2006 07:46 PM
srg
Aug 16, 2006 10:37 AM
deeeffache
Sep 10, 2002 02:29 AM
Finest
Apr 3, 2002 08:54 PM
