oil cooler in-line with turbo?
hey i have a b18 turbo my plan is to run about 400-450 whp and i was thinkin about installing a air cooled external oil cooler, i already have the gsr water cooled oil cooler but i was wondering if it would be a good idea to also put the air cooled one on, is it possible to put this inline with my turbo oil feed line or would that hurt the turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ganjasnack »</TD></TR><TR><TD CLASS="quote">hey i have a b18 turbo my plan is to run about 400-450 whp and i was thinkin about installing a air cooled external oil cooler, i already have the gsr water cooled oil cooler but i was wondering if it would be a good idea to also put the air cooled one on, is it possible to put this inline with my turbo oil feed line or would that hurt the turbo. </TD></TR></TABLE>
how do you think this would be beneficial? First, you can't run a -3 line to an oil cooler. There wouldn't be enough flow to keep any pressure in it to fill any kind of cooler and be effective.
If you REALLY want to run an oil cooler, get a sandwich adapter and run -10 lines to a cooler.
I'm too considering an oil cooler, my oil pressure at cold start is around 60psi and once its hot it drops to about 10-8psi on idle which is in my opinion way too low.
Water temp wise it stays around 83-85 degrees on idle. When driving hard it can go to about 100 while crusing it drops to about 80.
I'm defenitly up for an external oil cooler once I recovered from my build and got some $$$
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yakuza »</TD></TR><TR><TD CLASS="quote">
i dont think those are healthy temperatures for any motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_accord94 »</TD></TR><TR><TD CLASS="quote">I hope he's referring to degrees Celsius.</TD></TR></TABLE>
He's from "Stoke on Trent". That's not exactly a borough in New York City.
He's from the U.K. So yes, celsius.
