What size tires for 16 inch rims on del sol?
Old Sep 7, 2008 | 11:38 PM
redline870's Avatar
Default What size tires for 16 inch rims on del sol?
ok ive decided to go with 16" motegi traklites on my 93 del sol. what size tires should i get for these rims. the "recommended tire size" according to tire rack is 205-40-16. is there any way i could run a 45 or 50 series tire or will i have rubbing problems? i plan on taking the car to the track every once in a while so im looking for good performance as well.
Old Sep 8, 2008 | 12:09 AM
i drive a honda's Avatar
Default Re: What size tires for 16 inch rims on del sol? (redline870)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redline870 &raquo;</TD></TR><TR><TD CLASS="quote">ok ive decided to go with 16" motegi traklites on my 93 del sol. what size tires should i get for these rims. the "recommended tire size" according to tire rack is 205-40-16. is there any way i could run a 45 or 50 series tire or will i have rubbing problems? i plan on taking the car to the track every once in a while so im looking for good performance as well.</TD></TR></TABLE>
if you're not lowered.
i run 55 sidewall height on my 99 ex
Old Sep 8, 2008 | 04:46 AM
nub's Avatar
nub
205/45/16 here. I ran 40's and they were a little harsh. Like stated above if youre not dropped very much run the bigger sidewall. Something else to keep in mind is there arent a lot of tire choices in a 205/40/45/16
Old Sep 8, 2008 | 04:45 PM
TheJGB3's Avatar
The best size to run would be a 215/40R16. This tire is EXACTLY the same diameter as the stock OE tire size (185/60R14) of 22.7inches.
redline870
Apr 15, 2009 05:16 PM
redline870
Apr 7, 2009 07:37 PM
redline870
15
Feb 5, 2009 10:20 PM
dustinsterk
Jan 7, 2004 08:20 AM
delsol3982
Dec 29, 2003 08:48 PM
