OEM type s pistons with sleeved block
Old Sep 6, 2008 | 04:55 PM
meanshyguy's Avatar
Default OEM type s pistons with sleeved block
I was just wondering if type s pistons are compatible with iron sleeves?
Old Sep 6, 2008 | 05:21 PM
vinuneuro's Avatar
Default Re: OEM type s pistons with sleeved block (meanshyguy)
Should be fine considering the other Honda blocks use cast pistons. Although, why would you run such a setup? It's the worst of both worlds.
Old Sep 6, 2008 | 06:29 PM
98vtec's Avatar
moderator emeritus
Default Re: OEM type s pistons with sleeved block (vinuneuro)
Golden Eagle mentioned before that it is not a good idea. Those pistons are not designed to run on iron walls
Old Sep 6, 2008 | 07:13 PM
JTCdudeman's Avatar
Master H Technician
Default Re: OEM type s pistons with sleeved block (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">Golden Eagle mentioned before that it is not a good idea. Those pistons are not designed to run on iron walls</TD></TR></TABLE>
x2....
1. Rings were designed for FRM
2. piston expansion rate concerns
Old Sep 7, 2008 | 07:49 AM
meanshyguy's Avatar
Default Re: OEM type s pistons with sleeved block (JTCdudeman)
Understood, I'm trying to get a used block since mine is badly scraped, I didn't wanna bore it out since FRM is kind of tricky to hone or bore and I already have oem size pistons, I got some offers on sleeved blocks so that's why I wanted to know. I'll just keep searching for a non-sleeved block, thanks!!!
Old Sep 7, 2008 | 08:09 AM
vinuneuro's Avatar
Sell your Type-S pistons, should be easy. Send the block to Golden Eagle or DonF. Should be around $300 shipped and back to have the block .25mm overbored. It's a good idea to hone when replacing pistons anyway.
Old Sep 7, 2008 | 08:27 AM
meanshyguy's Avatar
Anyone knows their website or how to contact them?
Old Sep 7, 2008 | 08:28 AM
98vtec's Avatar
moderator emeritus
http://www.google.com/search?q...fox-a
shrirag
May 17, 2007 08:21 AM
evade this honda
Jul 28, 2006 07:20 PM
ekVtecPower
Jun 27, 2006 11:18 AM
NoVALude
May 13, 2005 02:06 AM
Toretto
Dec 4, 2002 06:10 PM
