Type A & B Pistons
Old Dec 4, 2002 | 03:55 PM
Toretto's Avatar
Default Type A & B Pistons
I have noticed that Honda sells Type-S pistons in type a and type b, whats the differance? Just curious, may be getting hooked up with a set of type-s pistons.
Old Dec 4, 2002 | 06:00 PM
Mike95lude's Avatar
Default Re: Type A & B Pistons (Toretto)
Their bore is slightly different due to casting imperfections in the making of your block. I don't remember which is larger of A or B. You need to have the exact size in replacement pistons that your block designates for them to fit properly. Some blocks may have 3 "A pistons" and 1 "B piston" or any other combination. Unless you can get a mix of A and B replacement pistons you'll want to have your cylinders honed to accomodate the larger of the two in a full set.
Old Dec 4, 2002 | 06:10 PM
Allstar's Avatar
New User
Default Re: Type A & B Pistons (Mike95lude)
DCsquirm88's Avatar
A pistons are the larger of the two. You can find out what size pistons your block uses by removing the head and the sizes are stamped on the block. Or you you can just get .025 over size type s pistons and have your block bored and honed.
JmurGSR98
Nov 3, 2010 01:27 PM
dk4ever
Dec 31, 2008 08:39 PM
DAGAME
Jan 7, 2006 08:26 PM
boostinh22
Aug 31, 2005 04:01 PM
NoVALude
May 13, 2005 02:06 AM
