need help on a choose
Old Sep 6, 2008 | 04:07 PM
My JDM EJ8's Avatar
Default need help on a choose
hey everyone, well i'm planing on doing a motor swap on my civic and the motor i'm planing on putting in my civic is the D16Y8. Now here's my question I have a 97 civic HX which comes with the 5 wire O2 sensor, and im not sure what im suppose to do with that sensor ones the motor is in and i use the P28 ecu. Does anyone know what im suppose to do with the O2 sensor?
Old Sep 6, 2008 | 04:11 PM
Kendall's Avatar
Replace it with a 4 wire O2 sensor.
Old Sep 6, 2008 | 04:17 PM
My JDM EJ8's Avatar
Default Re: (Kendall)
but the connector is different its a little bigger,
Old Sep 6, 2008 | 04:25 PM
Kendall's Avatar
You can replace the connector as well. It's really not that hard. Or you can repin the 4 wire sensor into the 5 wire plug. It's really not that hard either.
Old Sep 6, 2008 | 04:48 PM
My JDM EJ8's Avatar
i wasnt sure if i could do that because theirs 5 wires going into the connector and im not sure which 4 wires to use
Old Sep 6, 2008 | 04:53 PM
94EG8's Avatar
Seagull Management
Default Re: (My JDM EJ8)
time to get out some wiring diagrams, compare the two, one wire wont be used.
Old Sep 6, 2008 | 04:54 PM
My JDM EJ8's Avatar
Default Re: (94EG8)
well thats going to be hard since i dont have the 5 wire o2 Diagram can anyone help
Old Sep 6, 2008 | 05:00 PM
94EG8's Avatar
Seagull Management
Red seems to be the odd color out.
Old Sep 6, 2008 | 05:04 PM
My JDM EJ8's Avatar
Default Re: (94EG8)
so i shouldnt use the red then
Old Sep 6, 2008 | 05:08 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My JDM EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">so i shouldnt use the red then</TD></TR></TABLE>
Exactly
Old Sep 6, 2008 | 05:10 PM
My JDM EJ8's Avatar
Default Re: (94EG8)
but would the wires from the 4 wire o2 be the same the one on my car?
huskmusk
Jun 13, 2005 01:19 PM
dropd4door
Dec 27, 2004 10:22 PM
dropd4door
Dec 27, 2004 09:53 PM
alexb16hb
Apr 3, 2004 11:21 AM
Dancing is Forbidden
Nov 18, 2003 08:51 PM
