need opinion on fixing a blown engine
Old Sep 6, 2008 | 09:40 AM
crxcess's Avatar
Default need opinion on fixing a blown engine
the motor is a b18c5 type-r
I bought just the complete bottom end.
here is what I know. the motor had been assembled by a local race shop, but the owner went with a pre-set tune and the first time out , the motor detonated and blew.
it has no miles on it since the rebuild, has je pistons and pauter rods. #3 cylinder sleeve is cracked all the way down on one side.
I know one of the pistons is damaged, and I really need to completely check the condition of the remaining internals.
my questions is , would you sleeve this block or just replace it with a gsr block?
Old Sep 6, 2008 | 05:21 PM
Combustion Contraption's Avatar
Default FV-QR
Depends what you want to do of course. Only sleeve it if you have the intention of serious levels of boost, or going larger than 82mm on the bore. If not, get another block.
Old Sep 6, 2008 | 10:45 PM
vtecwhore's Avatar
* B A N N E D *
Sleeve it or throw it away.
Old Sep 7, 2008 | 05:13 AM
thevtecnician's Avatar
Default Re: (vtecwhore)
I agree with everyone else. As some food for thought, the money you might spend on sleeves and installing them would get you a fresh gsr block or better
Old Sep 7, 2008 | 10:17 AM
crxcess's Avatar
Default Re: (thevtecnician)
I do want to run some boost to it at a later date, but probably not more than 10-12 lbs.
That is true. I could probably just buy a replacement short block. Is there anything about a type-r bottom end that makes it worth saving? meaning, is there a significant difference between the R crank and the GSR crank?
I would love to get 300hp to the wheels. how safe is that with stock sleeves?
Old Sep 7, 2008 | 10:22 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (crxcess)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxcess &raquo;</TD></TR><TR><TD CLASS="quote">I would love to get 300hp to the wheels. how safe is that with stock sleeves?
All motor will require sleeves and then some.
Boosted, stock sleeves are fine.
Old Sep 7, 2008 | 10:38 AM
PyroProblem's Avatar
sleeve it and bore it to 84mm...That way youll have a beefy bottom end good for n/a or turbo later down the road...
It could be the last block you ever need!
And if the ITR crank is still good, def keep it...
Theyre supposedly a little better than the gsr.(different counterweights?).
Old Sep 7, 2008 | 04:10 PM
egb18c5's Avatar
Default Re: (PyroProblem)
the itr crank is 4 pounds heavier, if i remember correctly
Old Sep 7, 2008 | 04:32 PM
DonF's Avatar
Default Re: (egb18c5)
Needs more compression. Only 1 piston, good high compression engines get atleast 3. They were not trying.
dc2krazy
Apr 9, 2014 07:54 PM
B00stedEh3
Aug 5, 2007 08:04 PM
jdm'dc2sc61
Apr 9, 2005 02:13 PM
myDC4rox
Jan 17, 2005 10:35 PM
JICsube
Jan 18, 2003 11:42 AM
