A/F Ratio's on all motor...
Now.. This MIGHT come across as a mildly dumb question.. But.. What are good safe A/F's to run on an all motor setup?
When I was running my boosted D I was running 12.5:1 and that was considered safe.. Are the same rules going to apply to an all motor setup? Or is it different.
I would think that AFR's are AFR's.... And that it wouldn't matter what kinda setup you have.. But just to make sure.. I wanted to ask.
Please no Flaming!
Please no Flaming!
Your likelihood of detonation is less with N/A, so you can run at MBT (mean best torque), which is usually closer to 13.3:1 or 13.5:1 if I'm not mistaken.
Depends on compression, fuel octane, efficiency etc...
12.5:1 on 91-93 oct on a motor with 12.5:1 c/r and below is fine.
You maybe able to make more power at 13.0-13.5:1 depending on the setup etc.
Ignition timing is VERY important when it comes to tuning a motor aswell, don't forget.
Another thing to take into consideration is the fact that not all widebands read the same, especially sniffers versus an o2 in the exhaust stream :-)
ive always wondered that?
say you take two of the same wide bands, both calibrated the same... one in a bung and one in the tail pipe.. How different would they be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gstrudler »</TD></TR><TR><TD CLASS="quote">MBT (mean best torque)</TD></TR></TABLE>
maximum brake torque
mhgleitz
Nov 19, 2003 03:33 PM
advance concepts
10
Jul 17, 2003 12:39 PM
